Home Built Engine Dyno - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
  #46 (permalink)
Old 08-03-2013, 12:16 AM
Originally Posted by Silver Shadow View Post
Should be.
What happens is the speed drops to half, and the rotor becomes a less efficient pump with less ability to pump itself dry through the outlet orifice restriction.
Because you have not changed the incoming water flow, the drum fills up more, and the torque resistance stays the same.
If you keep reducing the rpm and not altering the incoming water flow, the drum fills even more. Once the drum is entirely full of water it cannot fill any more.
At that point the water brake is at its fullest mechanical resistance, and any further reduction in speed would reduce the torque holding ability.
So a small water brake will work fine with high power high rpm engines.
For big torque low rpm engines you need a bigger diameter water brake.
Bike engines are easy to hold, big capacity high boost turbo diesels very difficult.
ok... thanks, i will try to designing now, maybe i will ask questions in the future..thanks for the help
  #47 (permalink)
Old 08-03-2013, 01:40 AM
if i want to use water pump for water brake dyno, is it possible for a water pump running at 11000 rpm or higher?
  #48 (permalink)
Old 08-03-2013, 05:02 PM
Problem with any ordinary water pump is that the torque to drive it varies a lot with rpm, which makes controlling it even more of a problem than a proper water brake which is self correcting for changes in rpm.
  #49 (permalink)
Old 08-03-2013, 09:23 PM
oohh..so i should design a water brake dyno with stator and rotor,, right?
  #50 (permalink)
Old 08-03-2013, 09:29 PM
Yes if you want to do it that way.
Why don't you build an eddy current dyno instead ?
Much easier to control than a water brake.
  #51 (permalink)
Old 08-04-2013, 01:19 AM
i need to run the dyno up to 3 days i think...so i thought water brake dyno will be great because its dissipation to heat.
the second is, i dont know how to design a eddy current one, because its electronic aspect, i am not good enough at that subject..hhaha
  #52 (permalink)
Old 08-04-2013, 01:39 AM
Water brake of the size you are thinking about can run a total loss water system, so yes that part is pretty easy.
Eddy current machine just needs a big air blower to cool the brake disc.
The advantage is, it offers DIRECT and very fast electrical control of the dyno load, you don't need variable speed pumps or flow control valves which introduce a whole lot of extra control problems and are something extra to go wrong.
I am an electronics guy, and my own home rolling road dyno is eddy current, so my opinion is probably a bit biased.
But that is how I would tackle what you are trying to do if it was my project.
  #53 (permalink)
Old 08-04-2013, 02:21 AM
so can u teach me how to design a eddy current dyno? because i know nothing about that...i am trying to design a water brake now, even though i cant calculate the mechanical aspect correctly...
  #54 (permalink)
Old 08-04-2013, 06:42 AM
mercmad63's Avatar
Last journal entry: An update
You are asking a great deal here ,in fact what you asking is what someone would expect to aquire in terms of knowledge over a period of several years at university,with at least 4 years of techincal training in the use of machine tools.
I have all of the above experience as it happens but even so it was still easier to hunt down an unused peice of gear.
Your basic need then is a device to hold a pair of round turbines in a housing,
One is engine driven,one is fixed to the rotor housing .
The housing has to be fed a constant,controllable flow of water .(allow the water to get hot and boil and you will not get a proper braking effect).
This housing must be free to rotate through an arc of 45 degrees.
An arm of 500 mm length must project off the housing so it pulls against a load cell. this cell sends it signal to your PC where you can read off the pressure being exerted on it by the engine.
Add more water,and you are increasing the amount of effort required to turn the engine driven turbine and thus more pressure on the load cell.
Thats what a dyno does.
So, to get around your first task...a turbine. The most effective is the Fluid coupler from a truck or bus which is not a torque convertor. OK,thats a hard one ,but they do exist especially in the UK where trucks such as Leylands,AEC,Foden etc used a preselector type trans and the huge diesel engines produced a lot of torque.Far more than you will ever see from a car engine. A car torque convertor will not work,they are too weak and you don't want a torque multiplier effect.
The actual size or design is not as important as keeping the water flow constant and the temperature down below boiling. And dynos will boil water quickly under load.
The only way to control water temoperature is to use a cooling tower,a Big one!. So start looking around slavage yards etc for air con cooling units which will fit where you want to operate. Pouring water down the drain is not a great idea ,it is expensive and wasteful.
OK ,you got this far and the thought of finding a turbine is too hard... I live where these parts are available and I didn't bother looking too hard...
here is the patent document for the DPX style of dyno. These are actualy very small but can handle huge horsepower,
All you need to do is down load the drawings and dimension the drawings yourself .
Hydraulic brake or dynamometer
The document goes into detail on how it works. Here is one depicted here. Not very big is it? it was sold at Auction in the UK for 95 pounds.
Now, an eddy dyno..if you do not have access to a lot of water , the next best option is get a Truck or Bus retarder. These are mounted on big rigs behind the trans and work on the principle of creating a magnetic flux which the truck attempts to turn .They turn the torque into heat energy but in the case of Dyno,the retarder is connected by an arm to a load test cell ,
Eddy current brake - Wikipedia, the free encyclopedia
Now,you need to be able use a few formulas for calculating just how much force is being transfered to the load test cell (look on ebay for plenty of examples for sale) so if you read this document,on page three are all the formlae you will need.
http://www.sussex.ac.uk/Users/tafb8/...ngOverview.pdf
  #55 (permalink)
Old 08-04-2013, 08:16 AM
how should i determine how much debit of water will i use (Q)?
can i know ur email?
i get this formula, T = w * r^2 * p * Q
where T = torque of the shaft (engine)
  #56 (permalink)
Old 08-04-2013, 08:17 AM
w = angular velocity
r = impeller radius
p = density of water
Q = debit
i want to calculate the impeller radius, but i dont know the debit (Q)
Title for home built hot rod cranky1 Hotrodding Basics 5 10-20-2009 08:51 AM
Home Built and never satisfied. psy4s Introduce Yourself 4 02-02-2008 09:33 PM
Home Built Fuel Injection PsychoBandito Engine 3 08-28-2007 08:06 AM
Home built air compressor OneMoreTime Garage - Tools 5 05-21-2007 06:47 PM
Home Built Stuff Novaman78 Hotrodders' Lounge 20 01-25-2005 05:13 PM
