Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Home Built paint booth..EXTREME
Old 04-15-2013, 12:09 AM
nathon001 nathon001 is offline
Originally Posted by Slipangle View Post
Learn something from how turbochargers are designed. Too much airflow can be dealt with by ducting the intake for the fan and having a gate that either pulls air from inside, or from outside. (i.e. bypass the booth if you have too much airflow, then you can adjust how much bybass is used until you get the right airflow) Kind of like a waste gate in a turbocharger.
Thank you. Once I get the booth running I will perform some simple test to test the air flow. I hope all is good . I tryed to make this booth as close to a production booth as I could. I hope all my head aches will pay off.
