Home Built paint booth..EXTREME - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-06-2013, 08:57 PM
Originally Posted by EddieK View Post
Do your exhaust fans have sealed motors... that is, are they approved for use in areas where they will exhaust FLAMMABLE air? If not, you may be asking for trouble. Also, what means will you have to dry the compressed air?
Well…. The sales pitch on this fan says it is “completely sealed with thermo protection.” Does it have a stamp on it that says “safe for dangerous atmospheres,” no it does not. I believe it is because of the blades. They are galvanized. Not aluminum or plastic. Yet the loovers are plastic.
As for the drier, I always ASSumed I would have to buy one of those expensive water separator and drier combo things.
And on a side note: I got home Friday but my dad killed my weekend with a C10 454 swap…. We swapped out the 305/th350 and dropped in a 454/th305 (2nd th350 was “rebuilt”). Turns out the 2nd th350 is $H(T and did not move the truck forward. So today we put the original th350 back in the truck….. So, nothing was done on the booth……
  #17 (permalink)
Old 05-21-2013, 09:02 PM
Very nice job. I highly recommend a refrigerated air dryer if your budget can swing it. Before i got mine I put an old external engine oil cooler in line just after the compressor followed by one of the cheap water seperators from harbor freight and then had a box fan blowing air over it. It was ghetto but I was suprised how much moisture it condensed.
  #18 (permalink)
Old 05-21-2013, 11:27 PM
Fast41dodge's Avatar
Home built paint booth
Nathon, did you use explosion proof fixtures and wiring methods. In my 50+ years in the electrical trade I have seen several home built spray booths go BOOM. The scariest was a guy that had cordoned off half his garage with plastic sheeting. One evening after he had just laid the base coat he went in to get something to drink. The explosion knocked him and his wife down and the house off of its foundation and totally destroyed their son's bedroom (it had a common wall with the garage). By His grace the son was out riding his bike with friends at the time it blew. Just curious.
I'm just finishing up a 40' x 60' shop with a two post lift, a bathroom, a craft room for my wife, lots of overhead storage and a lockable tool crib. I am going to build a metal framework that I can use outside and cover it tightly with plastic. I helped a friend years ago build one and it worked great. It was 12' wide, 10' tall and 24' long. He used a former heater squirrel cage fan that was cleaned up then boxed up with filters sealed to the box. He bought a ceiling fan speed control to regulate the speed.
Good luck on your project. I hope to do my own painting too, once I get the shop completed.
  #19 (permalink)
Old 05-22-2013, 07:03 AM
Wish it was in my yard! Let us know how it turns out.
  #20 (permalink)
Old 05-22-2013, 07:47 AM
Jim Rockford's Avatar
World Famous VF-14
Last journal entry: Cleaned it up...
Sucks I have to bring this up nopw. but if you are going to be spraying water around, you should have have a concrete or concrete block knee wall installed at the bottom about 6-12 inches tall before the bottom plate, as it in now the water will rot out the bottom plate being as how its sitting right on the concrete. other than that it looks nice , you should post this up over at
The Garage Gazette - Index lots of tips and tricks for garages over there.
  #21 (permalink)
Old 05-27-2013, 03:59 AM
Penobscot Packards
If you get a chance, show us some photos
  #22 (permalink)
Old 08-29-2013, 09:53 PM
Got some work done!
Still not seeing the light at the end of the tunnel.
  #23 (permalink)
Old 08-29-2013, 10:00 PM
The OSB will be covered with white 4'x8' sheets of "shower vynil", only on the walls. I don't plan to hose down the ceiling.
  #24 (permalink)
Old 08-30-2013, 08:00 AM
Mitchman's Avatar
Grand Master of the Universe
1,200 cfm each. I hope you plan to throttle those as conditions require. On humid days that much air movement can cause excessive blushing.
  #25 (permalink)
Old 08-30-2013, 09:24 PM
the fans are on separate switches. I am hoping to just kill one and get the desired flow.
there will be a huge learning curve with this. my friends and I have 6 cars between us, for practice.
  #26 (permalink)
Old 08-31-2013, 12:00 AM
Ok. Many people have asked me how the heck I plan to filter the air as it comes into the booth.
I will have 10 like this (the filters are unside down):
mounted in the ceiling, like this:
So, there will be 40, 20"x20" filters letting in air.
This is after they pass a "pre-filter" in the attic vents.
  #27 (permalink)
Old 08-31-2013, 06:14 PM
Mitchman's Avatar
I'll need your address... in May. I have my own guns.
  #28 (permalink)
Old 08-31-2013, 07:01 PM
no problem. Be prepared to give lots of advice.
  #29 (permalink)
Old 09-12-2013, 02:24 PM
My brother-in-law talked me out of the 10 filter sets. Instead there will be 9. It is more symmetrical. So 36 filters.
This is what an F250 four door looks like inside the booth. with the doors open a thin man could work around the truck.
  #30 (permalink)
Old 09-12-2013, 02:41 PM
my home built paint booth! xpsyclonex2002 Garage - Tools 18 05-16-2011 08:37 AM
Real booth filters for the home booth markha Body - Exterior 2 07-17-2009 10:15 AM
Home paint booth 71haulnazz Body - Exterior 1 06-11-2009 04:18 PM
Home paint booth, walls? djdavis Body - Exterior 9 11-11-2004 10:51 AM
Home Built Garage Paint Spray Booth BIGISLANDROADRUNNER Introduce Yourself 4 07-15-2004 03:51 AM
