At home bushings - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-24-2006, 12:07 PM
At home bushings
I just put the rear control arms and 12 bolt back under my 1970 Skylark. The suspension seems to be free of binding. I welded the arms to stiffen them and to save 500 $ from not buying Hotchkis. I pushed in Energy poly urethane bushings in my vise. Boxing the arms helps because the stock arms could deform when squeezing in the new bushings.
Clint
Old 06-24-2006, 01:02 PM
Jake_Dragon's Avatar
Last journal entry: New Carb
I used a bushing press, it looks like a large C clamp.
One thing to try if you are having problems getting the bushings in is to put them in the freezer over night.
I have 2 more cars to do.
Old 06-24-2006, 09:48 PM
rubber isolator
I am working on the front of the 1970 Skylark and I am wondering whether I really need the rubber isolator that goes on the top of the coil spring between the frame. Thanks
Old 06-25-2006, 06:20 AM
I would use the one you have or replace it. It will squeak if you don't.
Isn't Hotrodders.com basically an online "car club"?? schnitz Hotrodding Basics 23 04-10-2006 07:14 AM
Mustang-II rack & pinion mounting bushings?? NASCAR314 Suspension - Brakes - Steering 4 02-08-2005 12:53 PM
Finally got the car home. Fade to Black Hotrodders' Lounge 5 07-15-2004 10:13 AM
Urethane Bushings - Yes or No?? Jim Weeks Suspension - Brakes - Steering 5 05-01-2002 08:12 AM
