Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Home A/C a-coil for a air compressor air dryer?
Old 12-28-2012, 07:27 AM
BWS BWS is offline
Got a new camera,see if this works.One is the "infamous" Franzinator....with external cooling coil(total loss system,IOWs 1/4" tubing taps into water supply but instead of tying back in,it simply fills a bucket.Only use this when AC is runnin non-stop.....and the water is simply adj to dribble).
The other pic is a copper coil.Its 3/4 that was simply coiled around a big sander drum or sumthing?Anyway its gonna be installed after comp.....
I need to tig up another expansion chamber on comp outlet...then plumb the above coil in....just need the time to do it....duh.
Good luck with your system.
ID:	70137   Click image for larger version
