Since nobody else wants to post one to help you out, I'll try it. The purpose for a cowl hood is to provide ample clearance and air for your carburetor/carburetors, especially with the use of a big intake manifold or possibly a supercharger. My advice is to get a stock hood and cut out a symmetrical hole that'll fit around your engine junk. Then see how tall your cowl needs to be. All a cowl is a piece of metal that tapers up with two pieces of matching metal on each side. Make sure both sides are the same size and shape the top piece. If it's for the street, I'd recommend extra braces to help support a steel hood, and a vent screen so you don't get squirrels living in your engine compartment, along with a good seal.
