home made ladder bars - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-01-2003, 12:58 PM
les les is offline
Post home made ladder bars
I would like any information on building my own set of ladder bars.
Old 02-01-2003, 04:44 PM
5.0Towncar's Avatar
Post
All they look like to me is some 2 inch rigid square tubing,some U-bolts that aren't curved on the bottomm, and some rubber stops on the ends. I could be wrong, but I've seen some on trucks that people made that looked the exact same and it beats spending 100-200 bucks. P.S. I would put some on my Towncar but it has coils in the back and I don't know how to make 'em for coils. Steve
[ February 01, 2003: Message edited by: 5.0Towncar ]</p>
Old 02-01-2003, 07:05 PM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Post
I would recommend doing some reading up on chassis design. There is a good chassis book that Summit sells. It explains how to setup a chassis, and can help you see what the ladder bars need to do. There are several things that you must keep in mind. As for the material, if you have access to a TIG welder, I would build them out of Chrome Moly tubing. If not, mild steel would also work.
chris
