Home Made Metal Break.....anyone done it? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-10-2006, 02:10 PM
Last journal entry: 99 soft tail standard I painted
Hey guys,have any of you ever made your own metal brake?If so do you have any pics,or plans.Im gonna build one with or without your help!....lolI have some ideas on how to do it,but your help would be great!
Old 02-10-2006, 02:37 PM
I made one using angle iron, pipe, and some rod! I'll have to take some pics of it.
I've used it to make various brackets with 3/16 inch steel and aluminum flat bar. Works well, but I need to make a few minor changes to it to work great!
Drew
http://firstgenfirebird.org/show/closeup.mv?CarID=642
Old 02-10-2006, 03:11 PM
zonk's Avatar
Home Built Rods No Rules
Last journal entry: Home Made Sheetmetal bender plans
Check my project journal, may help
Old 02-10-2006, 04:21 PM
Dang Zonk!That thing looks great!Its a little more complex that what I had in mind,but it gave me alot of good ideas.I have made one that is small,2 feet I think,but I need something bigger for door bottoms and stuff.
Old 02-10-2006, 09:57 PM
New Member
Last journal entry: Regrouping
I just made one out of 2x3x1/4 angle iron. Welded it to a base plate, put some pins in the sides for pivot, and stuck a couple of handles on it. I made it 3 ft wide. It'll bend a nice crisp 90 edge in 1/8 easy. Haven't tried anything thicker, imagine it'd do it too. I'll get a picture of it tomorrow.
Old 02-10-2006, 10:47 PM
Last journal entry: Latest picture
I will take a picture of mine in the morning and post it here. Dan
www.geocities.com/dantechfab
Old 02-11-2006, 10:01 AM
Here's the one I made! I went to the store that sells this type of brake with my digital camera and pull-out tape, and that's where I got the plans. I built this about 10 years ago for about $100. The one in the store was around $1400, well worth the effort. The picture is a little dark, but you'll get the idea.Dan
Old 02-11-2006, 03:44 PM
Dang Hemi43,you are the man!Thats one heck of a nice break! Thanks for the help and the pic!
Old 07-30-2009, 01:29 PM
Metal break
Has anyone ever made one ? do you have plans or some pics that may help me out. mike
Old 07-30-2009, 02:13 PM
I made a 48" one for about $60. It's so easy, even a caveman could do it. No plans, just right out of my head. Angle iron, 1/4" stock, square tubing, a bunch of bolts, a couple of hinges is all it is. It works just fine.
Old 07-30-2009, 02:44 PM
Do you have machining abilities?
Old 07-30-2009, 04:31 PM
Shelby1's Avatar
Steel Dreams
Here is a small one that I made many years ago to bend mount brackets and tabs when I worked in a race car fab shop. It would bend up to 3/16.
Kenny
Old 07-30-2009, 04:40 PM
life is a temporary assignment
Here's a press break I built..
ID:	39726   Click image for larger version
Old 07-30-2009, 04:47 PM
Jon's Avatar
Jon Jon is offline
Hotrodders.com Administrator
Wiki Edits: 7314
Anyone have plans? Can we post them to the wiki?
Old 07-30-2009, 04:50 PM
DanTwoLakes's Avatar
Wiki Edits: 22
That's a pretty ingenious trigger you've got there Randy! Is that just an air powered gear motor connected to the hydraulic jack?
Welding Books Magnus_Jager General Rodding Tech 6 11-29-2005 04:57 PM
Dent Repair Randy Ferguson Body - Exterior 25 11-26-2005 10:00 PM
my doors got stretched nomad57ry Body - Exterior 17 12-02-2004 07:51 AM
Kustomsledd fuel tank, how I made it... DrChop General Rodding Tech 4 10-28-2003 01:47 PM
Synthetic for break in? What weight ? (engine and cam break in that is) sizemoremk Engine 5 08-14-2003 05:50 AM
