you basucally have to add some anti detonant agent, The only one i know of is tolulene, an organic solvent that when added to gasoline raises the octane rating of the gas, but to get to 105 or above you have to add quite a bit, like 10-30% depending on what octane rating you start out with
you can also add methanol bt this changes the jetting requirements fo the carb, Here is a copy paste from : www.turbofast.com.au ANTI PRE-IGNITION ADDITIVES WE now come to the use of additives for reasons other than power increase. In this chapter we will deal only with additives that can be of assistance to us in connection with Pre-ignition and the other problem of Detonation. We again go through our three basic fuels in the same order. WHEN USING PETROL . . . We have three additives in Methanol, Acetone and Benzole (Benzene) and all of them are introduced with the main object of reducing Detonation by increasing in effect the Octane rating of the total fuel. Pre-ignition in general should not present a problem when using as basic fuel petrol. Methanol in Petrol. This is the best from the point of view of reducing Detonation, followed by Acetone and then Benzole in that order. Methanol can be added in all proportions up to 100 percent, but as an additive limited to 10 percent will give an Octane increase of about 5 points. For example 98 Octane can be increased to 103, or looking at it another way, cheap fuel of say 91 Octane can, by the use of 10 percent Methanol, or approximately three quarters of a pint per gallon, will produce fuel of 96 Octane. Acetone in Petrol. Can be used up to 100 percent but with the nominal 10 percent will give an increase of 3 points rather than 5. The major difference from Methanol being that due to the higher calorific value of Acetone, the consumption does not increase so much, but still provides a higher octane rating. Benzole (Benzene) in Petrol. Again can be used up to 100 percent but with the 10 percent amount will provide in points a rise of 2. In many cases this additive is used to counteract detonation since some 10 percent will, in certain cases, provide enough rise in octane rating to do just that. WHEN USING METHANOL . Now we come to Methanol as the main fuel, and as additives to reduce Preignition and/or Detonation we have two. Acetone in Methanol. Here we are concerned only with Pre-ignition since Methanol has itself a very high octane rating, and is therefore to be regarded as almost free from detonation problems. Once again our figure of 10 percent is the most advantageous use of the additive, as over that figure has a declining effect in proportion to the amount used. The effect of using this additive is to move the auto-ignition point upwards, and this was fully explained as will be remembered. |
The best home made race gas you can have for a performance increase consits of 93 octane pump gas and 10% nitromethane, ( this is the brew I use for nitrous) without forged pistons though, youll melt those pistons like butter...I havent ever went past 10% and wouldnt recomend going past 10% either...<<<<<tis enough
An internal combustion engine can burn more than 2 ½ times as much nitromethane to a given volume of air than it can methanol. Last edited by 2wld4u; 07-17-2003 at 08:43 AM. |
Here is the stuff I use, be sure to brows the site for tech info
http://www.pricechemical.com/max_race.htm |
1.) Car Craft is made by a bunch of idiots.
2.)I think you believe your Californian govt's brainwashing too much. |
it is true though, it really isn't beneficial to run a higher octane that your engine requires as it takes more cylinder pressure to get as explosive combustion. in retrospect if you run to low of an octane you get detonation.
If you do not believe it try running a car that doesn't need premium on regular then premium (with a stock engine of course) You will see that it may not have the power with the premium |
YEA !!!!! I can use everclear for octane booster!
now thats dual use Quote:
"Will I gain power with more octane" NO!! The engines octane requirements make sure they don't knock or ping. Only reason I see to increase the octane is to prevent ping, once you get the ping stopped with a level of octane going higher won't give you any more power.
In other words, if your car runs great and doesn't ping or knock at an octane rating of 87, running on gasoline with an octane rating of 90 or more will make absolutely no difference. Last edited by GearHead69; 07-17-2003 at 11:07 PM. |
I got some gas from a place that had really low prices and it made my truck run like crap and my my moms car ping
I just went up to autozone grabbed some booster and it runs good now I wandered why their gas was 1.29 while the other gas stations gas was liek 1.40 somthing |
