Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Home made SAS ?
Thread: Home made SAS ?
Old 08-09-2008, 07:03 AM
Old Fool's Avatar
Old Fool Old Fool is offline
Originally Posted by robs ss
Theres a difference in a supplied air pump used for breathing air and getting breathing air off from a regular air compressor or the system your using.
There is some risk involved in using supplied air, and as far as rigging up your own system from the pump your talking about, you increase the risk.
To many things can go wrong, I wouldn't attempt it.
I worked close to 30 years with supplied air, scba, negative and positive type respirators.
We trained people on how to use them and we also did all the maintenance on the systems.
Supplied air is not something you want to experiment with, just don't go there.
Rob
http://www.1969supersport.com
Please explain how a pass through turbine pump can make the air unacceptable for breathing. It is a turbine, not a piston compressor.
Thanks!
