Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Home made SAS ?
Thread: Home made SAS ?
Old 08-09-2008, 02:35 PM
oldred oldred is offline
Originally Posted by scrimshaw
Do you think that 'oil-less compressors' would still be susceptible to this problem?
Most likely not but the air would still need to be filtered and it should not be attached to a sealing type face mask unless it used with an approved type regulator designed for breathing air. A regulator failure on the line going to a sealed face respirator could easily cause serious injury or even be fatal and a regulator designed for normal air use would not be nearly accurate or dependable enough at pressures that low.
