Home made spacer? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-04-2007, 09:35 AM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Home made spacer?
Hi,
I have a problem, & I would like some help please.
I had to get some really tall valve covers for
the girdle to fit, & they have large a/n
fittings for the evacuation system, I need
to raise the plenum, but they have no spacers for
what I have, So, I have some cutting boards made
from that hard white stuff, I have 3/8, 1/2, & 1" thick
I want to use one of these as a spacer, (it will be a
good heat stop also from the manifold to the plenum)
with the thin paper gaskets on both sides of the spacer
any thoughts on this?
Thank you,
rich
Old 10-04-2007, 09:57 AM
302 Z28's Avatar
I see no problem with using what you described, other than making sure it is not affected by gasoline. I would place some of it in a pan of gasoline, cover it and let it sit for a week or so. If it is not affected I would have no problem using it.
Vince
What do you guys think of this home made truck. NEW INTERIORS Hotrodding Basics 16 11-14-2007 01:33 AM
Aluminum Rad or Home made fan shroud? sandiegopaul Engine 18 06-14-2005 02:10 PM
Home made parts dipping Jamescoop General Rodding Tech 6 02-14-2005 11:40 AM
Home made oil primer nova69 Engine 17 04-11-2004 08:22 PM
carburator spacer Echofive Engine 10 11-07-2003 07:18 PM
