Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - home made spray booth
Old 03-29-2006, 06:44 PM
theHIGHLANDER's Avatar
theHIGHLANDER theHIGHLANDER is offline
Originally Posted by OneMoreTime
Just use the clear or translucent sheeting that is used for construction or painting..put some 2x2 studs about every 4 feet and attach the plastic with lathe screwed over the plasic to the studs..makes a good temporary dust wall..I think it is 3 or 4 mil that I get..
Of course you will need some filters for intake and exhaust and a big fan to move the air..you can use the cheapy type filters for a one time kind of deal to make a simple crossflow booth..
Sam
Just like he said, maybe you don't need to even stud it. It may help. The final tip I can add in here is to wipe the plastic down with a polyester rag before you begin to shoot the paint. This creates a little static and the sheets become a dust magnet. One more tip. Blow off the ceiling area real well the day before. The nice part about the static "cling" is also that much of the overspray dust will get stuck to the plastic. Easy clean-up.
