Home made tools - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 04-11-2006, 09:19 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
Well I dont know if this counts as a tool or more of a attachment but it was one of the more complex things I made from scratch. . .
Its called a" stinger" for moving Mobile homes across black top roads just like on the back of a "toter" this was when the little machines they have now were way expensive.
Bull dozer's don't do good on asphalt
I thunk it up all by myself
Man I was sweating it because I didn't know if it would work but it did
I couldn't tell if the tractor would wheelie or not until I hooked it up theoretically it was 50/50 but I knew if it DID wheelie I could fill the bucked with dirt or something for counter weight
4" bore 4' stroke Hydraulic ram with a electric over Hydraulic "monarch pump" 12 volts that fit on the back of a 1971 CASE CBK 580 back hoe
1" plate for the whole thing
The back hoe detached
The ball had a double hitch & I made a stand for it too as seen here
Blurry sorry
Took about a month to build after hours & was the only one in the area I know about that could move mobile homes on pavement
It never got painted because I got hurt & had to leave the job
& I never got to weigh it either lost all the digital pictures to a virus too they probably scrapped it for beer money by now
R
Name:	STINGER FOR BACK HOE #3.jpg
ID:	11530   Click image for larger version
Name:	STINGER FOR BACK HOE #4.jpg
"SlowRide66"
"Illegitimis non carborundum"
Crankshaft Coalition Master List of Hotrodding Forums
  #17 (permalink)
Old 04-11-2006, 09:39 PM
powerrodsmike's Avatar
Wiki Edits: 161
Here is some more
I made my own tubing bender. I have several others but none of them worked like I wanted them to.
This one gets really close to the fitting if I want it to. The part with the bolt through it flips over to bend tubing or close to the tubing nut. There is a small notch on the stationary part of the handle to do close offsets. The die rolls around to make putting the tube in easier. It is helpful when you are working in close quarters like under a car.
Name:	mikey tubing bender.JPG
ID:	11526   Click image for larger version
Name:	mikey tube bender closed.JPG
ID:	11527   Click image for larger version
Name:	mikey tubing bender working.JPG
ID:	11528   Click image for larger version
BE different....ACT normal.
  #18 (permalink)
Old 04-11-2006, 10:00 PM
schnitz's Avatar
Last wiki edit: Building a new shop
Last journal entry: Christmas 2008 came early!!!
Wiki Edits: 54
I fabbed up a tool to help get the clutch fan/pulley off my '97 C1500's water pump....See pics.
In a while, Chet.
Name:	OSV pulley holes.JPG
ID:	11538   Click image for larger version
Name:	ISV pulley holes.JPG
ID:	11539   Click image for larger version
ID:	11540   Click image for larger version
Name:	tool in use.JPG
ID:	11541   Click image for larger version
  #19 (permalink)
Old 04-11-2006, 10:02 PM
Wiki Edits: 161
Here's some mora....
Here is a little edge roller I made for doing little trim pieces. It will go around curves too. I made the flanger also.( the flanger was way fun. I had to make a holder to put a die grinder on my lathe tool post,(live tooling, mikey style), so I could modify a 5/8" end mill so I could cut the T shaped die block that fit over the jaws on the vise grips. It only took me about 6 hours to make that tool and save the 35.00 it would have cost me to buy a set of flangers.)
The block looking thing goes in my press and will squish a GM steering shaft back into a double "D" after it gets shortened.
I have scads of this stuff. Mikey
Name:	edge roller.JPG
ID:	11533   Click image for larger version
Name:	edge roller with edge.JPG
ID:	11534   Click image for larger version
ID:	11535   Click image for larger version
Name:	double d crimp.JPG
  #20 (permalink)
Old 04-11-2006, 10:08 PM
Wiki Edits: 161
Originally Posted by Rob Keller
Home made pressuriized sand/media blaster holds about 700lbs of stuff.
110 lb ones run about just over $1,000 mine cost about $25
R
Hey Rob, Are you sure that isn't your thermos? mikey
  #21 (permalink)
Old 04-12-2006, 12:49 PM
This is good. It's always interesting to see how we can manage to create things that we need. If you dont mind i'll borrow a lot of ideas here lol.
  #22 (permalink)
Old 04-12-2006, 02:58 PM
Rob Keller's Avatar
Wiki Edits: 38
In the day time as far as the DEA know it 's SAND BLASTER!!
At night when the moon is right its a still
Fuels us & the race cars
Zoom Zoom Zoom
Originally it was a commercial pool filter
R
"SlowRide66"
  #23 (permalink)
Old 04-12-2006, 04:40 PM
Here are a few of my home made tools.
The added piece on the square allows for a better foot on curved stuff, such as the radius on sq. tube.
The tramels are very handy. and radius can be 20' with a full length of tubing.
Wedges dogs and 7's. We all know wedges will move mountains with a few raps of the hammer.
Half clamps, VERY handy, tack and clamp. Never toss out a broken tool!!
Hope these help someone out.
Joe
ID:	11553   Click image for larger version
ID:	11554   Click image for larger version
ID:	11555   Click image for larger version
  #24 (permalink)
Old 04-12-2006, 08:09 PM
Rob Keller's Avatar
Wiki Edits: 38
do thse work with a table ?
R
"SlowRide66"
  #25 (permalink)
Old 04-13-2006, 09:40 AM
Wiki Edits: 161
It's fun to share. BUT- If I see my idea on a tool rack somewhere being produced and sold by 1rookie tool company we will have to share a little the other way though. hahahaaha. (that's why i don't share the GOOD stuff. just cant't trust everyone.)
So what kind of car are you working on, 1Rookie?
some pics would be cool.
later, mikey
  #26 (permalink)
Old 04-13-2006, 12:34 PM
Geez dont worry about 1rookie tool company!!! For years I played (helped) others with theyre projects. a freind Nova SS 73, Chevelle 70 things like that, earlier in life I had a road runner 69 I paid 2500$ for a while It was mint and I was the second owner (wish I still had this one$$$) and a nova 73 that I took apart and drag raced a couples of years. Then I bought a house with no garage thats why I was helping others. Now we just got a new house and the condition was it had to have a garage. 21 by 28 by 10 ft high while building it I installed 2 air lines per wall at 4 ft high in the structure and all the electrical stuff. 220v for the compressor and another for the welder + one more just in case. Ill post pics as soon I get some. The toys are a 95 mustang GT a Harley Road King 2003 and a my wife has a 2005 Sporster. But as soon i install a 4 post lift I'll find a project to play with. I need the lift bcaus I dont want to lose parking space for the stang and hogs.
  #27 (permalink)
Old 04-13-2006, 12:49 PM
I was forgeting my biggest toy.... a 2005 Peterbilt 387. Took all the sleeper interior out and modified it. Installed a folding table and stuff like that.
  #28 (permalink)
Old 04-13-2006, 08:58 PM
Lots of neat stuff here, Most is a bit dated (early 60,s) but some useful plans anyway.
www.machinebuilders.net/1_viewport.asp
  #29 (permalink)
Old 04-14-2006, 08:06 AM
Rob,
Yup, they sure do. But can be used any place metal. The "C" clamp one has been in any and all positions.
A lot of folks forget that you can do a lot of tacking of these or anything else to use for alignment, clamping, pushing or pulling, then just clean up the tacks when done .
Joe
  #30 (permalink)
Old 04-14-2006, 11:14 AM
gator412's Avatar
1955 2nd series Chevy Pick Up
Last journal entry: Body work and U bolts
Here is a pic of the car dollies I built. They work great and cost was minimal.
There are more pics of them in my journal on how I built them.
