Home made tools - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
  #46 (permalink)
Old 01-03-2012, 10:03 AM
bentwings's Avatar
bentwings
I always seem to need a gasket punch. those cool little tools you see advertized but never buy.
I had a bunch of chrome moly tubing scraps. 3/8 od and .058 wall....grind the od to a taper sharp edge and you can punch a neat 1/4 inch hole. Take another piece and use a 45 deg chamfer tool on the id and you have a 3/8 hole. when they get dull just resharpen them.
As long as you use .058 wall you can go inside and outside sizes all the way up the line. I have a small box of them in the bottom drawer of the big tool box. 2-3 inch long pieces work great.
They also work on carpet when you have to use a screw to hold it down. The drill and screw will always snag a thread and often pull it all the way across the carpet. Just take one of these punches and punch a hole first. I carried it a step further and punched the insulation too.
  #47 (permalink)
Old 01-03-2012, 10:05 AM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
Originally Posted by graydog
I made this MIG cart out of an old shopping cart. Cost for old cart = $5.00. If you buy a MiG, making a cart is a good first project.
I thought one of the rules of getting a new welder, was you had to build a cart, as your first project
the bottom/back half of mine was a BBQ/Smoker, and i'm sure the metal for the front half was something else in a previous life also
the only thing I bought were the two front HF casters
I really like your hose holder. I need to do something like that for mine. I believe wrapping them too tight can lead to breaks in the lining and gun so I wrap them as loose as possible. But when hanging over the hook on the side of my machine it still ends up being too tight. I need to make something like yours.
I used 2/3 of an ATV wheel, I would think you could make a smaller car wheel work well also
ID:	61387   Click image for larger version
  #48 (permalink)
Old 01-03-2012, 10:27 AM
graydog's Avatar
Thanks Brian, you are right. I was just trying to keep things clean in bags.
I will remedy that.
  #49 (permalink)
Old 01-04-2012, 04:58 AM
graydog's Avatar
I think you need to get those plastic bags out of your cart, that is a fire hazard with the sparks that can be flying around when you weld you are asking for it.
Thanks Brian. You are right about the plastic bags. I'll remedy that. The hose holder is made from two pieces of a bicycle rim welded to a hook to go around the neck of the bottle. I agree the hoses need to be handled carefully. I would run out and take a photo but I'm laid up with a bad ankle & knee after a ladder fell.
  #50 (permalink)
Old 01-09-2012, 01:05 AM
graydog's Avatar
Metal brake
The first home made tool is a metal brake I made a few years ago from new scrap steel I bought from a salvage yard. As you look at each photo, you will see how the brake works.
Photo #1
It has a solid 1 inch rod welded to an angle to hold the metal down. I pull up on the white round rod handles to open it to insert the metal to be bent. The white handles operate eccentrics on each end, opening the clamp.
Photo #2
This shows the white handles raised up, opening the slot to insert metal. That whole top piece floats at the rear and is adjustable forward and rearward.
Photo #3
This shows the jaws closed again, clamping the sheet metal.
Photo #4
This shows the bottom being raised by pulling up on both handles in front of the top clamp to bend the sheet metal.
Photo #5 & #6
I cannot upload 6 photos here so this is 2 in 1. It seems you will have to click on the link below th see the last photo.
On the left: Handles are back down, showing how it bent the sheet metal.
On the right: I slid the metal forward to show the bend in the sheet metal. I can move this to either end and make a corner bend, but it would have been better to have removable shoes to make a box corner. I use it all the time and it does a really good job.
ID:	61605   Click image for larger version
ID:	61606   Click image for larger version
ID:	61607   Click image for larger version
ID:	61608   Click image for larger version
Name:	Brake #5 & #6.png
  #51 (permalink)
Old 01-09-2012, 01:20 AM
graydog's Avatar
Bolt, Screw, & small part storage.
This is something I made from clean 1 qt. oil containers and cutting off the top side with a chop saw. It's one of the most useful things I ever made. Hanging on the right is a pan I made with the metal brake to pour bolts into and funnel back into the oil containers. Cost for the whole project = $0.00
Also, here are the last 2 photos of of the metal brake.
ID:	61611   Click image for larger version
ID:	61612   Click image for larger version
Name:	Screw & Bolt Storage.jpg
  #52 (permalink)
Old 01-09-2012, 09:00 AM
That break is friggin beautiful! And your bolt container is brilliant! Good stuff indeed!
  #53 (permalink)
Old 01-09-2012, 09:22 AM
graydog's Avatar
Thanks Brian. I don't suppose I ever knew......is it a brake or a break? You are probably right with calling it a break.
  #54 (permalink)
Old 01-11-2012, 01:49 AM
That is a neat setup with your folder. I have made 1 very similar except the hold down peices are held down with a threaded T-handle and screwed down onto the angle. These are supported with springs from an engine head. The only downful with mine is that the folded area is 3/16 round. It is not very "sharp" at the fold. I have not got a pic of it but the setup is very similar to yours graydog.
  #55 (permalink)
Old 01-11-2012, 02:20 PM
graydog's Avatar
Thanks, Mi chael. I pretty much copied the brake from a commercial model. I could hardly afford $1000 for it so I copied it.
My motive for posting the previous was to let youngsters know they can build some nice, useful tools for pennies on the dollar compared to store bought tools. I am 75 and destined to make things like this handicapped cart. I sorta copied it after a Palmer, which sells for $5500. This cart cost me $250 + labor.
Name:	3 Wheel cart.jpg
  #56 (permalink)
Old 01-12-2012, 04:34 AM
Graydog
You wouldn't by chance be able to post some plans of your folder? That or PM me your e-mail address and send it to me that way?
  #57 (permalink)
Old 01-13-2012, 01:55 AM
graydog's Avatar
Graydog
Drawings emailed. Will email photos tomorrow.
  #58 (permalink)
Old 01-13-2012, 02:01 AM
Thanks graydog. I got your email and replied back. Hope you are doing fine after your accident. Thanks again for the quick response!!!!
  #59 (permalink)
Old 01-30-2012, 01:48 AM
dinger's Avatar
This thread has been cleaned up and hopefully will stay that way. Carry on, guys,
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
  #60 (permalink)
Old 02-02-2012, 05:28 AM
cal1320's Avatar
Not home made, just improvised.
I was working on a job site and needed a 1/2'' allen wrench (hex key). Checking the local big box stores yielded no tool. However , as I was about to leave , I looked at the shape of the allen and it hit me. A 5/16 bolt head would fit it exactly. I bought a 5/16'' shouldered bolt and nut. I ran the nut down to the shoulder and could then insert the bolt head into the allen and tighten it up with the nut. At less than a dollar, it was a very cheap tool for a one time use.
