bob1193
Using square or rectangular tubing will increase the torsional stiffness but not enough to cause you any problems and using the longest arms possible will offset this somewhat. I have the same setup on a nascar lookalike 73 Monte Carlo and once I got the spring rates worked out it actually rides better than the original suspension. I also have no wheelhop and this used to be a serious problem with the car.
Good reading, I built this type of suspenion from scratch under my Model A. All I'm waiting on is my 401 Buick Nailhead engine to be finished and Dyno'd, and then I'll have it on the road.
Glenn |
Home made truck arm susoension
Seems like the early Nova's are a natural for this type of set up. I got involved with one in the late '70's.
To make a long story short, it was a '63 model with a full frame and the body mounted uni-body style. The rear suspension ended up being a truck arm setup. But we came from a Ford Thunderbolt angle. We found that mounting the front of the trailing arms 6" on either side of the front U-joint seemed to work the best. we also used heim joints at the front end and OEM rubber bushings at the rear. When this baby launched of the line, it acted just like the Thunderbolt did. Straight up and then skating to plant the rear. The 425 horse, 396, 4spd. gave me a scare that I can still feel today. That car is still around today with the same chassis it had in '77. Youngster |
truck arms
May find some Tips here>> http://67-72chevytrucks.com/vboard/s...d.php?t=387475
olds before chevy truck
the 49 olds we had in high school had that design also my donor 46 olds. It tended to lift the rear on burnouts. WE did a couple of all olds swaps in 59 and 60 . first was a 36 chevy then a 30 chrysler roadster. the olds had rubber biscuits between the arms and the frame mounts, we used a pipe on a breaker bar to torque them as hard as we could pull to compress the rubber. , the roadster was quick off the line excellent reaction, no hop like the 50 ford we raced against, On the chrysler we extended the arms and that got rid of the rear body lift. we ran 4 rear shocks, and panard bar and a rear sway bar.
just saw the pics, im trying to put the same thing is a first gen f body, im also putting in new straight back boxed frame rails. what do i do for the arm mounts?
i have the arms on the way, im gonna have to find a cross member alone or make one
