home made Zoomies needs bracket - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-17-2014, 10:43 AM
I made some zoomies cuz I had the time and I need to tie them togather but also fastin them to the car to make them secure.[no teathers yet]I can make a hanger from the frame near the pipes but I need some ideas if you can help.Thank you.
Old 03-17-2014, 10:56 AM
techinspector1's Avatar
Wiki Edits: 326
Interesting..........
Old 03-17-2014, 11:01 AM
Thanks.The pipes are for mock up and I will do better on the finish product.
Old 03-17-2014, 12:14 PM
327NUT's Avatar
Sorry but those aren't "zoomies" as in top fuel zoomies, those are extended fender well weed burners.....and why would you want to fasten them to the car? They have to be able to move a little as the engine torques.
Old 03-17-2014, 01:00 PM
ericnova72's Avatar
More for Less Racer
Without having a collector that all four pipes feed into, you are really killing potential power. 50+ HP and Torque.
If these are for looks and you don't care about power...or are running a blower - then carry on.
Old 03-17-2014, 01:46 PM
yes I have a supercharger on the car,about 1,000 hp
Old 03-17-2014, 01:48 PM
I see your point about moving and this is why I asked.
Old 03-17-2014, 02:47 PM
life is a temporary assignment
1000 hp... Do you have any problem with your car hooking ??? I see you have the old slapper bars..
Old 03-17-2014, 03:33 PM
the car hooks very well pulling the front tires off the line but wrinkle the hell out of the sidewalls with stiff sidewall slicks and tubes with 13# air.The SS springs are for 3800# car and mine is 3900 with me in it[scaled]
Old 03-18-2014, 05:40 AM
My engine/exhaust actualy moves very little with having a front engine plate but with the the thrust of the exhaust I worry.I guess I will have to weld them togather and see how much I can make it move pushing on it.
Old 03-18-2014, 06:35 AM
vinniekq2's Avatar
are you going to use a collector? any exhaust system at all or just for race?
Old 03-18-2014, 06:41 AM
33Willys77's Avatar
If your concerned about movement, strap all 4 together and put a rubber mount up to the 'frame'.
Old 03-18-2014, 07:19 AM
I was thinking about a short rubber mount!The car is for race but I made a collector for it as in my pic on the track above but I needed to redo the turnout so I started on the zoomies for fun.I may be able to go off the fender clip with a short rubber or even wire cable.
Old 03-18-2014, 12:44 PM
I would think about tethering them. Maybe the cable idea that NHRA requires. The kits usually sell for 120 or so. Southern Rods n Customs has em for a lot less and does some custom lengths. Looks pretty easy to fab; this link is more for ideas than anything. Weed Burners R Cool! Tommy Ivo loved em. They may give up power though, as has been said
Affordable Collector Tether System NHRA Approved
Old 03-18-2014, 01:02 PM
Keep the tubes from hitting the frame or body. Flat strap, welded across all 4 tubes on top with a tab and a hole. Put a corresponding tab and hole welded to the body seam. Attach the 2 tabs with thick reinforced rubber strap using 5/16ths bolts and nylock nuts.
The Following User Says Thank You to steeny For This Useful Post:
metalstorm (03-18-2014)
Home made tools 1Rookie Garage - Tools 66 02-16-2012 07:35 PM
home made tool michael cook Garage - Tools 6 02-28-2009 09:07 AM
Home made SAS ? Old Fool Body - Exterior 20 08-10-2008 10:30 AM
home made interior fennerford Interior 9 12-29-2004 07:32 PM
