Home Mechanic's Tool Guide
(don't remember seeing this here before)
HAMMER: Originally employed as a weapon of war, the hammer is used as a kind of divining rod to locate expensive parts not far from the object we are really trying to hit. ELECTRIC HAND DRILL: Normally used for spinning steel Pop rivets in their holes until you die of old age, but it also works great for drilling mounting holes in fenders just above the brake line that goes to the rear wheel. PLIERS: Used to round off bolt heads. HACKSAW: One of a family of cutting tools built on the chaos principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes. VISE-GRIPS: Used to round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand. OXYACETYLENE TORCH: Used almost entirely for lighting various flammable objects in your garage on fire. WHITWORTH SOCKETS: Once used for working on older British cars and motorcycles, they are now used mainly for impersonating that 9/16 or 1/2 socket you've been searching for for the last 15 minutes. DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your drink across the room, splattering it against that freshly painted part you were drying. WIRE WHEEL: Cleans rust off old bolts and then throws them somewhere under the workbench with the speed of lights. Also removes fingerprint whorls and hard-earned guitar calluses in about the time it takes you to say "Ouch!" HYDRAULIC FLOOR JACK: Used for lowering a car to the ground after you have installed your new front disk setup, trapping the jack handle firmly under the front fender. EIGHT-FOOT LONG DOUGLAS FIR 2X4: Used for levering the car upward off a hydraulic jack. TWEEZERS: A tool for removing wood splinters. PHONE: Tool for calling your neighbor to see if he has another hydraulic floor jack. TROUBLE LIGHT: The mechanic's own tanning booth. Sometimes called a drop light, it is a good source of vitamin D, "the sunshine vitamin," which is not otherwise found under cars at night. Health benefits aside, its main purpose is to consume 40-watt light bulbs at about the same rate that 105-mm howitzer shells might be used during, say, the first few hours of the Battle of the Bulge. More often dark than light, its name is somewhat misleading. PHILLIPS SCREWDRIVER: Normally used to stab the lids of old-style paper-and-tin oil cans and splash oil on your shirt; can also be used, as the name implies, to round off Phillips screw heads. AIR COMPRESSOR: A machine that takes electric energy produced in a coal-burning power plant 200 miles away and transforms it into air that travels by hose to a Chicago Pneumatic impact wrench that grips rusty bolts last tightened 60 years ago by someone in Springfield, and rounds them off. PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part. HOSE CUTTER: A tool used to cut hoses 1/2 inch too short. :D |
he he he
Thats way to funny...... I guess because it's all true!!!!
Keith |
And in the travel pack: duct tape and WD-40.
If it moves and it is not supposed to = duct tape if it does not move and it is supposed to = WD-40 C |
Beserko Bob who was the announcer for englishtown in the
70s has this on his website. http://photobucket.com/albums/v234/1sway/th_Sway.gif |
| All times are GMT -6. The time now is 09:49 AM. |
