@ Home piston coatings? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-02-2009, 07:09 PM
Is there a piston coating that can be applied at home and baked in a shop oven? Iam looking for piston skirt coatings and have searched and found everyone want you to send them your pistons. Is there another way.
Old 04-02-2009, 08:25 PM
dawg's Avatar
NAVY VETERAN
I did mine here
piston domes and skirts for 40 bucks each
unless you got a bead blaster and oven capable of over 600 degrees its best left to the factory to do this.
Cam Help shsouthard Engine 18 03-29-2009 09:33 PM
Piston to bore clearance in .010 rebuild Nsomnia Engine 10 03-09-2009 06:06 PM
QJet Power Piston Won't Come Out of Bore JohnTN Engine 1 06-01-2006 05:38 PM
302 piston dim. compared to 327 piston Dave Y. Engine 2 09-25-2002 08:55 AM
