Hotrodders Bulletin Board > Tech Help> Garage - Tools
Register now (free) or login to remove ads
Thread Tools Search this Thread share on Facebook
  #1
Old 10-16-2005, 01:51 PM
atlantis atlantis is offline
homebrew parts washer
Has anybody built a parts washer? I plan on using an electric fuel pump to pump the cleaner but am particularly interested in how others have built the filter system and what kind of cleaner they use.
Regards
Martin
Old 10-16-2005, 04:51 PM
Cebby's Avatar
Cebby Cebby is offline
www.TOOLandFAB.com
Last journal entry: 1UZFE (Lexus V8) swap into 1993 4Runner
I don't have any input for you, but I'm also interested in this...
Old 10-16-2005, 05:15 PM
cliff tate cliff tate is offline
parts washer
i have made one that works well i started with a center sump oil pan from a 3208cat (worked for a cat dealer for30yrs}then a fuel transfer pump driven by a small elc motor of a dish washer. the filter from a diesel engine(the primary one wich is a fine screen)so it can be washed, welded some legs on the pan and made a lid workes great. the center sump allows instalation of a heavey skreen to put stuff on above the varsol. a center sump pan of a 302 truck engine would work, but if you live near a cat dealer and smile at the servicr maneger you will likely get some freebees when he knows what you are up to ,a fuel pump off a oil furnace would work also. have fun. i also have a old dish washe in my shop for final cleaning works well, v8 heads fit. soap and hotwatter is very good for final cleaning engine or trans parts. be sure to sray lube the parts after wash as rust will develop fast. have fun cliff
Old 10-16-2005, 07:32 PM
bracketeer's Avatar
bracketeer bracketeer is offline
489 Lemans
Last journal entry: Street Legal
I made one from a kitchen sink. I used a pump out of an old side by side washing machine. The filter was from an oil fired furnace. I sat the ssembly on a 20 gallon drum.
Old 10-19-2005, 04:30 AM
Thanks so far for the input. There is something worrying me at the moment: I inquired about industry cleaners that are offered for such parts washers and found that these are TREMENDOUSLY expensive where I live.
What did you do? It's possible that such cleaners are cheaper in the USA, but probably not. These cleaners usually contain kerosene, is it possible to use normal kerosene which is probably cheaper, or does anybody have a special receipe for a cleaning mixture?
Regards
Martin
Old 10-19-2005, 08:16 AM
bracketeer's Avatar
489 Lemans
Solvents are expensive. I have in the past used varasol with mixed results. It's about 3 bucks a gallon.
Old 10-19-2005, 08:57 AM
OneMoreTime's Avatar
OneMoreTime OneMoreTime is offline
Wiki Edits: 3
Cleaning solvents
Yup they are very expensive but then since they are constantly recycled in the parts washer it may not be as much of an issue as is generally thought. for a homemade washer I woudl like to use 1/2 of a 55 gal drum so I can put a complete tranny or engine block on the washer. Now one will need to do a secondary cleaning before painting to make sure no solvents are left to interfere with painting. Might be best to just bite the bullet and get a replacement washer pump from your parts supplier as some of the jury rig deals wind up costing as much or more as doing it right in the first place.
OMT
I would rather make it work than make it popular..And if it does not work it will not be popular..
Old 10-19-2005, 10:27 AM
parts cleaner
go to finning in naniamo they sell varsol in a 5gal can reasonable price, varsol is more suitable than kerosine. cliff
Old 10-19-2005, 10:29 AM
OMT
my jeery riged washer is 10 years old and all i ever do is clean the filter, the made in china ones ar small and short lived
Old 10-20-2005, 04:47 AM
Bucko's Avatar
Bucko Bucko is offline
Rat Rodder
Regards
Martin
I just use plain diesel fuel in mine. Works well and when you leave it sit for a while all the heavy solids sink to the bottom and the remaining diesel is fairly clean.
I've found it works well at getting rid of the large amount of crap that accumulates and then I just give whatever I'm cleaning a quick degrease and hose. Job done.
BTW, my parts cleaner is a 60 litre drum on it's side and cut in half. It's welded to a frame with wheels and has a large(ish) pump underneath it.
Don't know what the pump was originally for, but it was cheap at a junk sale.
Old 10-21-2005, 12:56 AM
FrankR FrankR is offline
Yes.
Go to www.homier.com. Buy Homier item #04725. You cannot find a better pump for the price.
Get a drum. I had a friend at a dealership save me a 55 gal that had windshield washer fluid in it. Ideally I would rather have had a smaller one. Ask around and you might get one for free like I did.
I used an old steel kitchen sink. Use the drain too. I took a piece of screen wire over the bottom in case any small parts were to find their way to the drain. All free.
I added a flash lid. Just a piece of sheet metal hinged.
Get about 4 ft of 3/8" vinyl tubing.
The rest you can figure out. Mounting of the sink, rigging a spout.
Old 10-22-2005, 12:14 AM
roger1's Avatar
roger1 roger1 is offline
Diesel is at $3.15 a gallon down here in Texas.
I wonder if my powerstroke will run on Varsol?
Old 10-22-2005, 12:19 AM
roger1's Avatar
Regards
Martin
Do you really want to build one when you can get one of these?
http://www.harborfreight.com/cpi/ct...itemnumber=7340
http://www.harborfreight.com/cpi/ct...temnumber=42817
http://www.harborfreight.com/cpi/ct...temnumber=41108
http://www.harborfreight.com/cpi/ct...temnumber=35740
Old 10-22-2005, 09:39 PM
oldred oldred is offline
Roger, I don't own one of the HF washers but I know of a couple of guys that do and it seems they are one of the items from HF that work really well. One of the fellows rebuilds transmissions and the other runs a small engine/lawn mower shop and both use these things a lot, seems like it would make more sense than trying to build one.
Just a thought
Old 10-23-2005, 09:17 PM
ChevelleSS_LS6's Avatar
ChevelleSS_LS6 ChevelleSS_LS6 is offline
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
build your own for spare change and use the $79.99 for....
-a dyno session
-tools you can't build
-speed parts
-taking the wife/girlfriend/whatever out on a nice date
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "homebrew parts washer"
ThreadThread StarterForumRepliesLast Post
Maaco vs. At-Home Paint Jobnightrain_rodBody - Exterior12607-05-2011 09:25 PM
Are Ford Model A parts worth selling????1931 steveHotrodders' Lounge1205-23-2008 04:32 PM
paint thinner or mineral sprits for parts washer?shockers69Engine1710-19-2005 02:56 PM
a place to look for parts for sale or post parts for saleJake_DragonSite Suggestions and Help507-26-2005 12:55 PM
1964 Muncie M-20 parts question1964 Oldsmobile 442Transmission - Rearend304-10-2004 10:25 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
