Homebrew Tranny Cradles for use in Floor Jacks - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-26-2005, 01:19 PM
Cebby's Avatar
www.TOOLandFAB.com
Last journal entry: 1UZFE (Lexus V8) swap into 1993 4Runner
Anyone have pics of their setup? I figured I could just pull the cup that is in my floor jack and make a cradle of some sort with a solid bar/tube that would fit where the cup receiver is. Thoughts? Comments?
Old 11-26-2005, 01:35 PM
Fast Orange's Avatar
I made one a few years ago-
I found a piece of pipe that fit in the jacks socket,welded it to a 12'x16' piece of 1/4" plate and drilled holes to strap the tranny to the plate.Still a PIA-no lateral movement,no ability to angle tranny up or down.It did work better than lifting it by hand,though.
George
Old 11-26-2005, 02:18 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
go here
http://www.harborfreight.com/ and type in 507-vga
I used this on the C-6 in my 79 F 250 worked great and for the price you cant build it as cheap
SR66
"SlowRide66"
"Illegitimis non carborundum"
Old 11-26-2005, 03:42 PM
Cebby's Avatar
www.TOOLandFAB.com
Originally Posted by Rob Keller
go here
SR66
That's just what I was looking for. How can you go wrong for $36? I just ordered it! Thanks!!
Old 11-26-2005, 04:54 PM
frankenstang57's Avatar
waynenewtoneVil
Last journal entry: plans
Ah, but you may hafta modify it to work with non China Hydrolic jacks! But for $36- I'm sure you can make it work...
Old 11-26-2005, 07:45 PM
Cebby's Avatar
www.TOOLandFAB.com
Mine is the Advance Auto "Pro Lift" undoubtly some of China's best work also...
Old 11-27-2005, 12:20 AM
Rob Keller's Avatar
Wiki Edits: 38
I've got two 3 1/2 ton Craftsman 2 speed floor jacks
works just fine in both even comes with a snap ring for high speed applications
I have the scissor type too i used that one when I did the flywheel both are just like a sore peter ... can't beat it
I'd trade em both for a car lift and a ROOF
i wanted to get the $200. one but that is a catalog item
glad I was able to help
send pictures
SR66
"SlowRide66"
Maxi Fuse Problem starman141b Electrical 3 09-08-2005 02:28 AM
Pulling motor/ tranny 66 C10 66thom Engine 6 10-27-2003 09:46 AM
Wiring harness from scratch, fuse values norcal02 Electrical 3 09-16-2003 11:03 AM
Tranny fluid heating up engine??? black66 Engine 1 07-13-2003 09:18 PM
88 AOD tranny problems rflud Transmission - Rearend 9 02-17-2003 04:53 PM
