Homebuilt Dyno? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-20-2006, 02:09 PM
ckucia's Avatar
Homebuilt Dyno?
This is probably a dumb question, but is there any practical way to build an engine dyno for home use?
The "inexpensive" ones are about $10k.
I don't think it would have to be nearly as accurate as a good shop dyno. As long as it gave relative numbers and could identify the torque peak, that would go a long way towards tuning and evaluating different combos on a mild street engine. You could calibrate it by paying for some dyno time, getting figures, and then adjusting to match.
I did some web research and couldn't find anything besides what's being used by go-kart builders, and most of that won't scale up.
Old 01-20-2006, 04:17 PM
There is no "cheap" way to build a dyno. The dyno itself is not that expensive, around $6000 just for the "dyno core". Then you need a storage tank for the water, we use a 1000 gallon used milk tank, a pump, we use a 10 HP, lot's of copper piping and a control valve, we use a VFD controlled water valve. Now your close to $9000 to $10,000 and it's not installed yet. You need an enclosed explosion proof fire proof room, you need a data aquisition system, that's AT LEAST $5000 for junk and $15,000 for something decent with sensors. You need a computer, printer, a high volume exhaust fan, a fire suppression system, a filtered air intake box with ducting to outside air, and about 1000 other things you don't think of until your into the project.
I don't know of any "cheap" way to get into a dyno. I have tens of thousand in mine and we started out with a good base used system.
Old 01-20-2006, 06:05 PM
NAIRB's Avatar
The cheapest home built dyno I can think of is an old car chassis, and a G force meter.
You'll look like Mad Max, but it ought to do the job.
Old 01-20-2006, 07:27 PM
NXS's Avatar
NXS NXS is offline
wind & fire = guides to power
I saw an old chassis dyno that simply had large steel rollers with disc brakes at each end. It also had sensors that measured how fast they accelerated and that looked like all it was. I'm not sure how accurate it was but the concept seems firm, XXX Hp will accelerate XXX mass in xxx time.
To do it at home you could design something like a standard transmission linked to the rollers by way of chain, the engine would be reved to the start of the power band, for example 2500 rpm and held steady...then max throttle would be applied until the engine reached max rpm, say 6500 rpm and that time would be measured.
Carb settings or timing could then be changed and the test re-ran. If the time increased or decreased you would know if average power increased or decreased.
A real savvy person could run some formulas and also end up with average Hp...if they knew the exact weight and diameter of the roller.
Old 01-20-2006, 07:29 PM
I as well have always thought about building a engine dyno. If I am not mistaken most engine dynos use a water type brake, which I doubt I could build myself.
My idea was more along the lines of a intertia dyno. You could have some kind of real heavy metal drum (about the size of a 50gal drum) with a clutch mechanism to engage it to the motor and a disk brake to slow it down. It would have to be balanced perfectly and have a sufficent weight (I don't know what that would be? couple houndred pounds?)
Building such a setup I feel is very doable, now the trick is the computer part and measuring the output.
I would love to just have some junk engine in my garage on my own dyno and just make pulls for the hell of it!!
anyone else have any ideas?
Old 01-20-2006, 07:39 PM
NXS's Avatar
NXS NXS is offline
Great minds think alike?!!
Old 01-20-2006, 11:14 PM
I don't think a homebuilt dyno would be very practical but their may be an alternative… Have you herd of the G-Tech? They plug into the cigarette lighter and attach to the windshield. They measure the G-Forces and with some electronic wizardry they will measure ¼ mile times and HP and Torque. I bought the first generation one off ebay for something like $40 to play around with. The new ones have alot of bells and whistles and even make hp and torque graphs. These run someting like $275
They are by no means perfect but if set up right they are normally really close. What they are really great for is to measure before and after times, HP and Torque. For someting like testing diffrent setups this may be perfect.
Old 01-20-2006, 11:47 PM
74Ventura's Avatar
Good,Cheap,Fast.Pick Two
I was thinking about this too.Was thinking chassis dyno though,using an old packer/steamroller drum.
Old 01-21-2006, 07:02 AM
jim..'s Avatar
That 6 Cylinder Guy
So if weight,mass,and accelleration rate somehow equals horsepower(I don't know the actual equation)can't you figure hp pretty close if you know the weight/mass of the vehicle as well as accelleration rate?
Also I've seen hp rated in kilowatts or megawatts,so how about a drum connected to an old power generator(big one),by putting a load on it and monitoring the current output ?
Or how about this:
http://www.charm.net/~mchaney/homedyno/homedyno.htm
Old 01-21-2006, 07:18 AM
T buckets rule
I have a home made engine dyno that we use for Jr Dragster engines. It has a solid steel wheel 30" in diam and 1" thick a 30 hp eng can spin this wheel really quick. I can't imagine how big a wheel you would need to do a perfomance type car engine.
Here is a link to the hardware and software package we use.
http://www.performancetrends.com/dtm-hdwe.htm
Old 01-21-2006, 10:29 AM
ckucia's Avatar
Thanks for all the suggestions.
I was specifically thinking of an engine dyno as opposed to a chassis dyno.
I was hoping to build and tune and engine and then get an idea of where the HP and torque numbers were, so I could then use that info to make better final ratio choices rather than building the whole car and then having to keep swapping gears.
It would also help in determining if a 4 speed, 5 speed or 6 speed trans was the best fit for the torque band.
I know it wouldn't be a perfect predicter, but I thought it might be cheaper in the long run than experimenting after the engine was in the chassis.
Old 01-21-2006, 12:35 PM
If the flywheel on that Jr. drag dyno is that big, you would need a huge wheel weighing alot more then I thought.
Since most engine dynos use a water brake, maybe you could find some old industrial water brake(If there even is such a thing) or build your own. All the brake really is, is an impeller of sorts inside a housing and the water creates the resistance.
I guess you could also make something using air resistance like on some exersize bikes. Maybe build some kind of "fan" about 4 foot in diameter with the blades pitched at 90 degrees. with the blades pitched this way it would not pull itself in any direction and should create more resistance. It would have to perfectly balanced to handle the rpm. Hay with something like this it would engage alot easier than a gaint flywheel. I would also build a gaint super thick encloser for it in case a blade let go. I can picture it now, I just cant imagine what kind of sound it would make! A huge fan with paddle wheel like blades spining at 5000+ rpm!!!
This has got my going now, I do some research on air resistance dynos!!
Old 01-21-2006, 12:40 PM
NAIRB's Avatar
Dateline Anytown USA: Man Decapitated and Friends Maimed During Home-Built Dyno Testing.
You know, the idea of a home built wind resistance machine connected to a 400-500 horsepower engine doesn't sound like the safest thing I've ever heard of. Neither does very large, heavy spinning rollers or flywheels.
Nice ideas but read and try at your own risk.
Old 01-21-2006, 01:00 PM
T buckets rule
The people that built my wheel also make major parts for the internaional space station. Yes it has to be perfectley true and balanced, not to mention a good weld on the hub. That wheel will spin almost 2000 rpm at full power. I would hate for it to come apart or come out of the bearings.
Old 01-21-2006, 01:03 PM
NAIRB's Avatar
My dad had an old Johnny Pop two lung John Deere, you know the ones with the great big flywheel on it. He was tooling around the corner on it one day and that big flywheel decided to make a break for it. Right through the bank's fron window.
I'm glad there were no fatalaties.
Long Awaited 400 SBC Dyno Results Mad Maggot Engine 19 10-14-2011 07:29 PM
Drive shaft broke apart on chassis dyno Steam Roller Engine 6 03-08-2006 02:32 PM
dyno predictions zap60 Engine 26 02-16-2006 02:46 PM
Dyno disaster lust4speed Transmission - Rearend 5 03-01-2005 06:55 PM
Car missing while on Dyno? FBody Engine 11 09-07-2004 10:17 AM
