The fan location may be a bit inconvenient other than that it should be Ok. What are you doing for heat? Getting to that time of the year..
Sam
What I would do is run a couple fans on the garage door end with filters pushing air in and then just a single filter at your other door letting air out. That way your "booth" will be pressurized and you won't have a lot of air moving around inside stirring up dust. With a couple boxed fans you should be able to exchange the air in a single car garage in about 2 minutes. More importantly... make sure you have a high quality breathing mask or even better a fresh air system while your painting. No sense in ruining your health just to paint a car.
See how I did my booth HERE. Centerline HotRodsAndHemis.com “The only place you'll find a helping hand is at the end of your own wrist" - Joe "Dr. Olds" Mondello |
Like I said it takes about two minutes to completely replace the air in a single car sized booth with just two 20" box fans running on medium speed. Centerline HotRodsAndHemis.com “If money is what makes cars fast, mine otta be going 400 miles an hour!". - Felix Sabates |
The one thing to be aware of is that with positive pressure, any leak you have in your garage may get paint overspray stuck on the outside of the leaks. It can be a real mess.
Some paints like Omni are real bad about this because the overspray doesn't dry as fast as other paints. I prefer to have the fans to blow out rather than in due to this. |
If you're sucking more air out than your pumping in the visqueen will act just like a flag and flap with the air movement. If its pressurized it basically won't move at all. Also Roger1 is correct in that you will need to seal everything with duct tape to keep air from leaking out anywhere but where you want it to exit. In my booth it took about $10 in duct tape to seal it all. By the way, this booth wasn't the first I had built that way. I've done three cars in two different garages using this kind of booth and have been very pleased with the results each time. This one was done with DuPont Chroma Premere BC/CC and Chromalusion flames ![]() ![]() This truck was done with Omni single stage Hemi Orange And this one was done with Napa brand single stage Ford Candy Apple Red Centerline HotRodsAndHemis.com “The only place you'll find a helping hand is at the end of your own wrist" - Joe "Dr. Olds" Mondello Last edited by Centerline; 10-02-2011 at 10:07 PM. |
Centerline, Very nice paint jobs!! O.K. I hope I don't sound like a broken record, But This is how I was going to do my (1) car garage booth, I only have rigid walls and now I will put 2 box (20 in) fans underneath garage dr, enclose the rest of the garage dr top and bottom. Then my side dr (walkin) at the opposite end, but still on the side wall, should I put only (1) filter to exhaust? I will enclose the rest of the side dr, I just want to make it clear, thanks again, Dana
If you're not going to put plastic on the walls you could run a cross flow booth where you have just as much air coming in as going out. But if you're going to use plastic to cover the walls (I suggest you do if you don't want them painted too) then just keep more coming in than going out. You could use one fan sucking air out at your walk in door with the other two at the garage door pushing in. That will work. Make sure you use decent filters and let the fans run for an hour or two before you clean the inside of the booth. This will let any loose filter material to be removed before you paint. After you let the fans run a while, clean the inside of the booth the best you can to get any dust out before you bring the car in to paint.
Good luck with your paint job. Centerline HotRodsAndHemis.com "When buying a used car, punch the buttons on the radio. If all the stations are rock and roll, there's a good chance the transmission is shot." - Larry Lujack |
Don't let anyone fool you about a home booth. You will have to cut and buff the final product. No matter what you do you'll get some dust nibs and the occasional hair in the paint. Don't let that worry you though. Its all part of the painting process.
Centerline HotRodsAndHemis.com The most important things you learn are those things you learn AFTER you know it all. -- Chip Foose |
Well, I am about to try just that. I'm setting up my home booth right now and am planning not to cut and buff. We shall see!
I'm painting my '55 Chevy Bel Air hardtop. I'm going to start out by just painting the top and I think I'll be ready to do that Wednesday. Just a few dust nibs wont bother me but hair would. I'll be using a hood w/ supplied air and a full suit. I'm using 12" dual electric radiator cooling fan set for exhaust. I got a 12V 30 amp power supply off of ebay to run them. The fan set are 2000 cfm which I believe is pretty good. I thought this was a good alternative to expensive sealed fans and I had the fans just lying around anyway. I may post a picture tomorrow of my setup and see if you guys might have any suggestions. |
Centerline HotRodsAndHemis.com “It's better to go into a corner slow and come out fast than it is to go into a corner fast and come out dead." - Sterling Moss |
| Type of paint for Paint Booth | SuthnCustoms | Body - Exterior | 4 | 10-11-2010 05:47 AM |
| Different paint booth question | pavetim | Body - Exterior | 10 | 02-14-2009 07:35 AM |
| Question about new paint booth floor? | FRANKBULLITT | Body - Exterior | 5 | 10-23-2007 12:03 PM |
| Respirator for Homebuilt Booth | sha_ba_do_bang | Body - Exterior | 7 | 12-04-2005 06:44 AM |
| Paint Booth | hallamwillis | Body - Exterior | 2 | 04-21-2005 04:45 AM |
