Homemade Battery Tender
There was a recent electrical thread that had a post containing info on making a homemade battery tender. I've searched all over w/o success.
Anyone know where it's at? |
I am the first to head to DIY but trickle chargers (I assume this is what you mean by a 'battery tender') are so cheap why fool with DIY?
Double post!
This idea used one of those small chargers for tape recorders or whatever and I happened to have one (or three). Then, all that was needed was some alligator clips.
There is a battery mangement system with the brand name "Battery Tender". I have several, including two Battery Tender Jr. models. A 12v wet cell battery needs a constant charge in order to be up to it's potential. The Battery Tender line charge a 12v wet cell to a predetermined voltage, sense the voltage fall off at full charge and automatically switch to a "float" charge. The float charge is not a trickle charge, it is a constanty variable reduced charge rate designed to maintain a specific voltage in the battery. A constant charger, be it trickle or float WILL NOT damage a battery if the chrager is engineered correctly. I have had a Battery Tender Jr. on my generator for over 5 years. It sits up sometimes for 8 months before I remember to run it. It has never failed to turn over and start.
http://www.batterytender.com/default.php?cPath=11_3&osCsid=be75017ae20b5316a8a6 4f297ecd2b2e Vince |
Suitable for 12 Volt wet-lead-acid, Sealed-lead, gel, and absorbed mat Batteries. One LED turns Yellow, and Green to Indicate charging status. Automatic cut-off and then true float to maintain a full charge indefinitely Without harming the battery. Electromagnetic interference (EMI) is Controlled; TV, Radio, and other Appliances are not affected Also my experience is that most good quality commercial battery chargers taper and shut off as battery comes up to speed. For example I have a medium grade trickle/10amp/50amp charger at home that modulates the current based on battery voltage and turns completely off when fully charged so does no harm. If you are doing any hot rodding/car building at all I recommend you get a charger similar to mine w/ +10amp capability. Great for charging batteries for sure but is an invaluable 12V power supply to test electrical systems when a battery is not conveniently avaiable. For example, I am using mine currently to trouble-shoot my EZ wiring harness in my pickup project. I am still several months away from needing a battery and my charger is a great substitute for problem solving. Incidentally, here is the thread you were looking for in your original post. Last edited by willys36@aol.com; 03-03-2005 at 11:51 AM. |
Harbor Freight had 1 amp "battery tenders" on sale about 6 months ago. I bought two for $8 each. Both have been in continous service since, one on a motorcycle and one on various car batteries in the garage. I find it pretty hard to justify screwing around with light bulbs and Radio Shack parts to save $8 plus a couple of dollars shipping.
| Need help please with an electrical headake | bowtieorbust | Electrical | 15 | 01-26-2006 03:01 PM |
| Charging system info............... | poncho62 | Electrical | 11 | 11-26-2005 08:53 PM |
| Battery problem? | evltwin | Electrical | 11 | 04-10-2005 06:45 PM |
| Battery Exploded! | VWFan | Electrical | 14 | 12-05-2004 04:52 PM |
| starting issues...battery or starter? | 79454 | Engine | 6 | 10-25-2003 04:10 PM |
