Homemade Bellhousing Project... - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-10-2011, 09:37 AM
Basically, I am building my own bellhousing to adapt a Ford Toploader 4spd transmission to my old school SB Chev V8. I can buy one for around $450, but it's a heavy 1/4" thick steel monster, and I prefer building my own lighter parts if i can. I'm not concerned about it not being "SFI certified", as it's just a fun street car and i have no desire to make it legal for the track.
The mock-up began with an old 400 block and an empty transmission case. I am using the alignment bar from my rearend narrowing jig to keep everything straight and true. I spent a couple nights machining some steel pucks to fit in the block's main bearing bores and also the bearing bores in the transmission case. The pucks have an 1.501" hole in the center so that my alignment bar will slide inside everything to keep the engine and transmission bores concentric. I made a ring to center the plate that the transmission will bolt to, and a tube spacer that will set the desired distance between the block and transmission face. I have also made the rear plate that the transmission will bolt to, and have laid out the the flange that will bolt to the block and serve as a pattern for the block plate that will fit behind the flywheel.
Working in my spare time after hours, I expect it will take me a week or two to get it done. The transmission is getting some special work as well, getting faceplated in 2nd, 3rd, and 4th. I'm adapting an aluminum tailhousing from an SROD overdrive trans to replace the Toploader's stock iron piece to shed some weight. Also machined down the Ford throwout collar so that I can use my existing Chevy hyd throwout bearing.
Here's the drawing i started with to layout the block bolt pattern...
Here's the pattern I made out of 1/4" steel. All the hole locations were laid out, centerpunched, and drilled 3/16" so that the pattern could be transferred to the blank piece of 1/8" that it's laying on, which will be used to make the block protection plate. The steel pucks on the right are the pilot rings and spacer that i mentioned in an earlier post that locate everything in the correct positions for mock-up...
This is the block plate after it was cut out and drilled. The large hole in the center is for the crank's flywheel flange to stick thru, and the 2 larger holes on the sides are for the locating dowels in the block...
This is the pattern after i drilled it out and cut the center out. It is going to be the forward flange of the bellhousing that bolts to the block, the large hole in the center is necessary to clear the flywheel...
Here's the block plate on a block. The upper "wings" were added as mid-mounting points that will hang the back of the engine from the firewall...
Here's the block plate and flange on a block. The block plate will be sandwiched between the block and bellhousing as shown. I'll soon be creating a hole and pocket for the starter.
The mid-mounts incorporated into the block plate allow me to easily remove the bellhousing/clutch/flywheel from the car without needing to support the engine. Greatly simplifies clutch and transmission maintenance.
I welded the rolled ring to the bell flange, all the holes still line up...
When i made the parts, all the holes were drilled to the same size as the bolts that go thru them. My thinking was that it would keep everything as precision as possible during fab. After i'm done with all the welding, i'll drill them out one size over to allow easier/quicker assembly, maybe 2 sizes over if i decide to powdercoat it.
Here's the alignment bar in place in the block, as well as the spacer that sets the depth between the block and trans case...
Here's the trans case in position located by the pilot rings...
I had to check to make sure i'd created enough room to install a SoftLoc clutch, so i figured i'd snap a few pics while i had it out of the fixture.
I started making patterns for closing in the bell by laying out the the top section on posterboard. I quickly realized it was much easier to just cut out slightly larger pieces of posterboard, hold them in place on the bell, and simply apply a little pressure by running my finger around the edges of the steel. This puts a small crease in the posterboard and transfers the exact shape needed, a much quicker way to create a pattern...
The transmission plate is still only tacked in 4 places. After all the rest of the welding is done, i'll put the bell back into the fixture, cut the tacks, and re-position the plate for the best alignment possible before welding it in place. I doubt there will be any need to machine the block or transmission mating surfaces.
Still need to make a pocket for the mini-starter that's going on the car...
I'll add more pics over the next week or so until it's done.
To be continued...
Old 02-10-2011, 10:08 AM
geezer69's Avatar
Die standin' up
Last journal entry: geezer69 nova 63
dang, thats cool. i dont think ive seen this done yet.lookin foward to more pics.
Old 02-10-2011, 10:49 AM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
That is impressive, nice job!
Old 02-10-2011, 02:08 PM
ericnova72's Avatar
More for Less Racer
Very nice, you Sir are a Fabricator!!
Old 02-10-2011, 02:58 PM
302 Z28's Avatar
Very nice work indeed .
I had a bud in high school that had a 40 Ford Coupe with a SBC. All he did was use a standard Chevy aluminum bell housing and after centering the Ford trans (don't remember which one) drilled and tapped new mounting holes. Looked absolutely factory.
Vince
Old 02-10-2011, 03:30 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
I love it when i see thing's like this , very impressive
Cole
Old 02-14-2011, 09:03 PM
Added a cutout for the mini-starter's drive...
Added a starter pocket to the bell as well...
To be continued...
Old 02-14-2011, 09:46 PM
302 Z28's Avatar
Nice job.
Vince
Old 02-15-2011, 08:47 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Very cool!
Applying pressure to the card stock to transfer the dimensions was a good idea, too. In the olden days, guys would use the "ball" side of a ball pein hammer to do much the same thing when making gaskets, w/the difference being the ball could actually cut the gasket at the same time in some cases.
Old 02-15-2011, 11:08 AM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
Beautiful ! !
Old 02-16-2011, 05:45 PM
Very cool. Nice to see things take shape.
Old 02-16-2011, 05:54 PM
1930u's Avatar
Last journal entry: 1930u Its just been sitting
I love it. You have great ability!
Old 02-16-2011, 05:56 PM
eloc431962's Avatar
Wiki Edits: 37
To be continued...
I would let you build me one anytime.
Cole
Old 02-20-2011, 06:18 PM
Here's the finished product...
Old 02-20-2011, 06:27 PM
eloc431962's Avatar
Wiki Edits: 37
Looks like a fine job to me.
Cole
homemade h-pipe whatle Engine 5 11-06-2010 10:26 PM
Homemade dragster rednek_racin General Rodding Tech 1 06-02-2009 07:11 PM
After looking at the homemade mig welder... 4EyedTurd Garage - Tools 6 04-28-2009 05:58 AM
homemade chevy 427 86regal Engine 9 03-11-2008 12:50 PM
Homemade Rod speedydeedy Hotrodders' Lounge 110 01-30-2008 09:13 PM
