Homemade Fan Shroud? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-18-2005, 04:00 PM
My 14 inch electric Zirgo puller fan on a 18Wx24H inch radiator isn't keeping the engine cool while idling (mild 350 Olds engine in street rod). Works fine on the road.
I only have 1 5/8 inch clearance between the original mechanical fan mount and the radiator. This fan mount is 15.5 inches below the top of the radiator.
I was thinking about trying to cut a shroud out of a large plastic dish pan or storage container lid that could slip down between the radiator and fan mount. I would then mount the electric fan to the improvised shroud so the fan would pull through a larger area of the radiator.
Anybody tried anything like this before?
John
Old 07-18-2005, 04:09 PM
HemmiGremmie's Avatar
Last journal entry: 52 truck
I built one outta sheetmetal one time. It helped but still ran kinda hot.
Maybe try and match your radiator up with a car you can find in a salvage yard and use the shroud of it.
Only other thing is try a bigger fan or dual fans. HG
I was built with the body of a God! To bad it was buddah.
Hemmies rat journal below.
Old 07-18-2005, 04:10 PM
A answer of sorts..........
Walker Radiators make plastic shrouds ......maybe one could be adapted....
Old 07-18-2005, 05:32 PM
Wiki Edits: 49
I built this one out of sheet metal. It happens to be for a mechanical fan but there's no reason you could'nt do the same thing for an electric.
Old 07-18-2005, 06:08 PM
Nice work Centerline! HG
Aluminum Rad or Home made fan shroud? sandiegopaul Engine 18 06-14-2005 03:10 PM
electric fan - no shroud? Blob Engine 11 02-09-2005 09:29 PM
Clutch Fan malibuman66 Engine 18 01-01-2005 11:09 AM
fan rubs on shroud montea Hotrodding Basics 9 08-23-2004 09:25 PM
Radiator fan shroud Charles F. Smith Engine 5 10-02-2003 08:40 PM
