Homemade front axle - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-18-2004, 09:36 AM
teched's Avatar
New Member
Last journal entry: Z'd Frame
Homemade front axle
Has anyone out there made a front axle? If you did what did you make it out of? I'm thinking 2"square thick wall tubing, maybe???
Old 10-18-2004, 10:12 AM
BOBCRMAN@aol.com's Avatar
I have made them from 1 3/4- 2" .250 wall tube (round). With corresponding solid bar for ends. The most important part, aside from precise welding, is getting the Kingpin boss at the correct angle and parallel.
If this is a one only item, I would buy one from MAS in Minn. As you will have considerable time in building a jig or mill/welding setup and getting the correct size reamer for the kingpins. The reamer alone costs over $100.00.
Old 10-18-2004, 10:18 AM
teched's Avatar
New Member
Have you ever thought about cutting the axle ends of a stock axle and slipping them into the hollow tube?
Old 10-21-2004, 08:36 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Axle ends
Speedway has the axle stub ends that you need for this..
