Homemade low speed drill press conversion
Bought this awhile back off of craigslist for a decent price. 1950's Craftsman floor model DP. It was pretty scungy but ran well and the spindle spun true. I tore it down and cleaned it up. Here's a before and after.
http://img.photobucket.com/albums/v3...o/PA300002.jpg http://img.photobucket.com/albums/v3...o/P1010003.jpg The problem is I do mostly metal work so I need much slower speeds than what it provides. It was originally a variable (note the stepped pulleys) but even the slowest speed was way too fast for what I needed. A low speed conversion was optional back in the '50's but good luck trying to find one! So.....I decided to make my own. It's pretty simple, most anyone can do it! Here's all you need. Cost about $25 total. http://img.photobucket.com/albums/v3...2/P6090007.jpg Drilled a hole in the steel blank, inserted and welded the bolt to the blank. http://img.photobucket.com/albums/v3...6150003_01.jpg Flipped it over, welded the blank to the top of the DP post and installed the first bronze bushing. http://img.photobucket.com/albums/v3...2/P6160003.jpg Next, I slipped on the new step pulley and another bronze bushing. http://img.photobucket.com/albums/v3...2/P6160005.jpg Installed the flat washer and a nylock nut. Do not tighten! Installed new belts and there you have it! http://img.photobucket.com/albums/v3...2/P6160007.jpg The lowest speed I have is now 175 rpm! Perfect for cutting 1/4" plate or drilling forged axles! Bought the pulley from MSC, got the bushings and hardware at Home Depot and got the belts at a local small engine repair shop. This thing works great! I just built my spring perch and drilled lightening holes in it. http://img.photobucket.com/albums/v3...m/P8260003.jpg |
Should have made mention to drill the hole in the blank off center. This allows you to make belt adjustments.
Nice clean-up job on the drill press:thumbup:
| All times are GMT -6. The time now is 02:39 AM. |
