HOMEMADE Oval exhaust - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-04-2013, 04:27 PM
Messed around with making oval pipes for an engine swap project I am doing.
Used 2 bars that I have that are different sizes. Next time I'll cut a bar so the part comes out equal on both sides.
I slowly heated and pulled with the engine hoist at the same time I hammered
the pipe. Came out o.k.
Ideas/thoughts/questions welcome!
ID:	70291   Click image for larger version
ID:	70292   Click image for larger version
Old 01-04-2013, 04:39 PM
vinniekq2's Avatar
you can buy oval pipes. good for clearance issues.round pipes usually flow better because exhaust swirls when traveling
Old 01-04-2013, 04:49 PM
Buying oval, true! Dr.Gas? Anyway I need only a small amount and I have plenty of round pipe at home.
More time than money.
Flow is not as important as fit in this application. Stock 2000 Explorer 5.0.
Been a fun project.
Old 01-04-2013, 05:02 PM
geezer69's Avatar
Die standin' up
Last journal entry: geezer69 nova 63
cool, go ahead, looks good from here. practice makes perfect.
Old 01-07-2013, 04:14 PM
Silverback's Avatar
Boost Retard
I was tempted to post a "why bother. Just buy it" post but looking at it if u strapped one end down and pulled the other you could make transitions any size you need...
Honestly I've done stuff like that before but always cut lengthwise and welded flat pieces in. Probably better for flow but also significantly more work
Oval or Square lonewolf3197 Engine 13 11-05-2015 04:07 PM
making custom oval exhaust. muffler help please. AndersonRacing44 Engine 6 12-04-2010 08:56 PM
weird question: using square/ oval tubing to run large exhaust thru tight space lowROLLERchevy Engine 8 07-17-2006 08:58 AM
Looking for some Oval exhaust pipe 36scsc General Rodding Tech 4 02-08-2005 05:34 PM
049 oval versus zz502 #390 oval heads fast times Engine 8 10-16-2004 11:40 AM
