Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Homemade portable bandsaw conversion
Old 02-21-2013, 03:29 PM
timothale timothale is offline
Wiki Edits: 27
Band saw stand.
I didn't use as much tube -angle iron for mine. No pict . I found that clamping in a vise on the bottom by the trigger will cause it to stick later on, I use a 1 inch wide squeezer spring clamp to hold the trigger on, bent to fit I have an upright tube up the back side and another bracket that clamps it near the top handle. the bottom just rests in a curved piece that matches the shape
