Homemade portable bandsaw conversion - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-27-2013, 04:34 PM
barrnone50's Avatar
I like the band saw. But what about a update on the body Doctor? You did a great job on the 1/4s claiming to be a rooky hard to believe after seeing the completed 1/4s. Great job!
  #17 (permalink)
Old 02-27-2013, 05:09 PM
Last journal entry: '27 roadster quarter panels from scratch
Thanks man! The body is on hold right now. I've been concentrating on making it a roller. Got the front and rear suspension hung and most of an x-member built. Right now I'm working on mounting the '40 Ford pedal assembly and master cylinder. Sure is slow going!
  #18 (permalink)
Old 03-01-2013, 01:46 AM
barrnone50's Avatar
looking good on the your frame! should be a roller soon. I know it takes a while but you can tell you have put a lot of thought into your build. Your frame design is yours or did you get dimenisons from other source? what you did with rear end look pretty clean,would that be considered a 4 link? thanks George
  #19 (permalink)
Old 03-01-2013, 05:28 PM
Thanks! The frame design is mine. I copied the outer dimensions off the original subframe (which was a rusty, rotted mess). I Z'd the front x-member 3" and kicked up the rear 13". The rear isn't a 4-link. A 4-link has 2 upper and 2 lower arms. My rear is just 2 trailing arms thats suspended w/coilovers and centered with a panhard bar.
  #20 (permalink)
Old 03-01-2013, 09:11 PM
302 Z28's Avatar
Originally Posted by biggsteve View Post
also....in your yard sale trips, pick up an old electric sewing machine foot pedal. they work like a dimmer switch, but foot operated. great for any power tool. drill press. band saw. etc. plus, keeps your hands free.
Hardly rated for the load a portable band saw requires.
Vince
Finally bought a bandsaw jessicafd Garage - Tools 4 06-26-2011 08:06 AM
horizontal bandsaw motor problem buggyman Garage - Tools 12 09-27-2010 07:53 PM
bandsaw question... cutthroatkid Garage - Tools 9 04-29-2010 05:21 AM
Kalamazoo horizontal bandsaw C-10 Garage - Tools 10 05-16-2009 12:18 AM
Bandsaw Mills C-10 Off-Topic 3 09-28-2008 10:51 AM
