Homemade Rod - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-16-2007, 07:56 PM
31 five window
Last journal entry: grill and rear end
Homemade Rod
THese are some pics of an old friend's truck. We call him Iron Man Joe. He started on this one week ago. It is built on a stock S-10 chassis with 3 inch lowering blocks in back. Thought you might like to see it.
ID:	25580   Click image for larger version
ID:	25581   Click image for larger version
ID:	25582   Click image for larger version
ID:	25583   Click image for larger version
Old 11-16-2007, 08:12 PM
poncho62's Avatar
Wiki Edits: 5
Interesting....and I am sure its a lot of work.........But, sorry...............I feel that the independent front suspension on those s10 frames just doesn't suit that type of build. The front wheels sit too far back as opposed to the body and grill.
Old 11-17-2007, 06:01 AM
Last journal entry: frame build
Looks like quite a project. Not my cuppa, but go for it anyway. This is all about learning and doing. What is the shroud off of?
Old 11-17-2007, 06:27 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
He is doing a good job,but the s-10 frame is way too wide on the front...it is visible on each side of the grill shell. What is he going to do there to try and make that look better? By the way did he fab that grill shell? If not, what did it come off of?
Old 11-17-2007, 06:30 AM
79C10's Avatar
Viva la Migra!!
Looks really different . I like it. please keep posting pics of the progress.
Old 11-17-2007, 06:40 AM
31 five window
I agree that it would look better with front axle forward but pretty good for what he is working with.The grill shell is completely fabbed by ironman, he quarters and pie slices 3/16" pipe.I know it is not the best looking homemade truck out there,but for an old man on a tight budget Ithink it looka pretty good. I will post more pics after he adds the fenders and running boards.
Old 11-17-2007, 07:13 AM
31 five window
Sorry henry I forgot to address the front frame ? He said he is going to cut them back and put rectangle headlights there.Will post pics when he does.
Old 11-18-2007, 10:35 AM
31 five window
No new pics yet but will install engine and trans wednesday,will post pics then.
Old 11-18-2007, 03:14 PM
302 Z28's Avatar
Good gawd .
Vince
Old 11-18-2007, 06:16 PM
31 five window
302 Z28 I really appreciate your reply, but can't tell if it looks so bad it hurts you or if it is so much work it hurts you, please explain.
Old 11-18-2007, 08:05 PM
Its cool now,butI think that after the front frame overhang is addressed it and it is completed itll be one slick lil pickup
Shane
Old 11-18-2007, 09:01 PM
Wow, not my cup of tea either, but I give him credit for the fact he is out actually working on building something, unlike some guys like me. I'll have to see how it looks finished. Hard to beat the lines/look of the manufactured stuff. Least it looks way better then that thing vince built, but then again his only took him a few weeks too. Just kidden vince.
Old 11-22-2007, 07:28 AM
31 five window
New pics,He added headlight surrounds,windsheild frame and roll pan.I delivered his engine and tranny yesterday.
ID:	25711   Click image for larger version
ID:	25712   Click image for larger version
ID:	25713   Click image for larger version
Old 11-22-2007, 08:51 PM
classicautoresto's Avatar
Rust Buster
Last journal entry: birthday surprise
To each his own, but the "cow catcher" on the front to me is set low. As a suggestion, the grille would look better higher on the frame, then slam the whole front end to achieve the low look. Just an observation.
Old 11-23-2007, 06:56 AM
31 five window
You make a good point but its hard to tell because the ground is so unlevel there is a bump in the grass right under the cow catcher. Will have to wait and se when he puts it on concrete. I told him the same thing.The engine is a 1978 305 with a 350 turbo.I will post more pics as he progreses.
Junkyard Motors.. Zartan Engine 20 07-08-2011 07:52 AM
rods kustumz Engine 13 02-07-2007 04:35 PM
destroyed con rod bearings - pics and description - what happened ? lowROLLERchevy Engine 36 12-06-2006 09:10 AM
Rod and piston question Ratoflic Engine 2 02-10-2005 07:34 PM
?? Bore Sizes ?? ss crazy Engine 2 10-03-2003 02:51 PM
