Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Homemade tire dollies
Old 06-13-2010, 07:07 PM
IHRodder's Avatar
IHRodder IHRodder is offline
Farm equip wasnt meant to fly
I have a one car garage to work in.
With a welder, workbench, tools, drill press, pedestal grinder, etc, its kind of tight quarters in there when you roll in a vehicle to work on.
If I had some tire dollies to put under the tires of whatever Im wrenchin on, I could roll it to one side or the other for more access room around it.
I searched the web and found out that the cheapest ones for about $50 a set, like the black ones from HF arent really worth buying for heavier vehicles. The wheels dont have bearings in them and dont roll well under a load, as well as having a tendency to fold over if you push on them too hard and they arent straight.
The tire dollies that do work well start at more than I want to spend. About $100 apiece for the low end HF ones.
I also found some for sale that are solid steel and looked really sturdy. Still more than I want to spend. About $60 each. Hmmm. I could make something like this;
So, I looked around the web for people who have built their own homemade tire dollies and I found these;
I also found this thread on;
Home made car dolly
I have some steel, a torch, grinder, drill press and a welder.
We dont need no stinkin store bought dollies!
I began by looking for some casters. I needed them all to swivel, and I need about 300 to 500 pounds capacity for each caster, or about 1200# to 2000# per dolly.
Yes. Overkill!
After looking for a while, I ended up with these;
Capacity? IDK for sure, but a LOT! They have 6 inch fiber wheels and greasable ball bearings for the swivel and the wheels. Im guessing capacity is over 500# per caster.
I have a few sheets of 1/8" mild steel that I scored a while back, so I guesstimated and started cutting out some 14" x 14" squares.
Sizing it up.
I made a bolt pattern of the caster mount out of cardboard;
Transferred the pattern over to the sheet steel with a spring loaded punch;
Deepened the marks with a real punch and a hammer;
And drilled the holes;
Then I bolted on the casters;
I know the bolts are too long. I had them, so I used them. I will replace them with shorter bolts.
Here is the first one;
