Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - hommade A frame gantry crane. supplies?
Old 04-26-2011, 02:57 PM
OneMoreTime's Avatar
OneMoreTime OneMoreTime is offline
Hotrodders.com moderator
Wiki Edits: 3
I use these
http://www.harborfreight.com/2000-lb...inch-5798.html
They are a bit slower to operate but there is no neutral to them so they will hold in position and yes they will lift a motor and trans if needed..put 2 on one on each side as that will help in balancing a load if needed..
the cable will run to a block in the then to a block in the center of the lift. use a snatch block so it is easy to re rig if needed..
Sam
