Yea, the only real reason I used it was because I had to support the trans somehow. it was supporting maby 200lbs of transmission weight, the engine crane had the rest.. Using that with the engine crane is a big reason on why I want somthing better
Well, I took the first step in building this. I got the 5798 winch from HF. first impressions of the winch are, it's ok. It's 40:1 ratio so it's slow but it'll work. It has a 'hard spot' on the drum which tells me the drum is off centered. I think I'll take it to my local Napa and have the machinist turn it center and insert a bronze bushing. Wish I had a lathe. It will probably wear in and be just fine otherwise. But a bushing with a little grease on it won't be a bad thing
the better winch
I bought the truck crane and it had the gear to gear drive. I bought a big heavy wood stove for the shop at a garage sale and used it to load the stove up on the flatbed truck. My neighbor bought some livestock and his truck wasn't running and wanted to borrow mine to pull his 4 horse trailer. I was just leaving in the car and told him to just unload the stove in front of the shop. He cranked it up an inch off the bed. swung the stove out and started to crank it down. with the gear to gear winch and the weight he couldn't control it and the handle was spinning his hand around. It hit the ground but didn't break anything. The worm gear drive is slower but the design minimizes the possibility of it getting away from you. I have that winch on my crane now and also on my sheetrock lifter. I put on double nuts and use my right angle drill to power the lifter up or down then slip the handle over the DD flats and hand crank for final height.
Yep. Worm gear design works as a brake without any mechanical brake. That's 1 reason why I went with the 5798 winch.. The handle should be easy to turn loaded anyway.
After some space consideration, I want to make a boom crane ( sorta like an engine crane ) rather than the Gantry. This will allow me to work off of 1 side rather than 2, and allow dropping an engine/ trans in the frame a breeze with 2 winch's and hooks.. I now have 1 of the 2 5798 winches I will need. I still need 4 snag blocks/ pully's. I will attach the snag blocks into the boom with Forged Eye bolts and heavy duty quick links rated at or above 3,000 lbs
Tower and all supports will bolt onto the base, and the frame itself should be good for 2-3 tons, but being the winch is 1 ton, that will be my max weight.. I guess I could support 2 tons with the weight carried over both winch's, but I don't have anything that heavy. Tho I will make a load bar that can utilize both winch's Last edited by matt167; 05-02-2011 at 12:51 PM. |
| Recent Garage - Tools posts with photos |
| My engine crane won't fit under my frame rails? Any tips? | SinistrV6 | Garage - Tools | 27 | 07-20-2009 03:31 PM |
| gantry crane | jasrking | Garage - Tools | 0 | 07-22-2008 09:25 AM |
| gantry crane | jasrking | Garage - Tools | 2 | 05-15-2008 09:03 PM |
| how much supplies to buy? | adrock430 | Body - Exterior | 3 | 01-11-2005 07:53 PM |
| upholstery supplies? | elcaminoescondito | Interior | 10 | 12-01-2002 08:41 AM |
