The Honda - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-05-2004, 12:32 AM
Ghetto Jet's Avatar
current hot rod: CTS-V
Last journal entry: Lets Get Started With the Improvements
Unhappy The Honda
I got to work Thursday morning and antifreeze was coming out from under the car, I got under it and figured out it was the water pump. I was only 55 miles from home , fantastic. Poured almost a gallon of antifreeze in it and got it home, surprisingly the gauge didn't go any higher than it normally does.
Saturday, myself and my old boss, who is a real mechanic, put on a water pump, timing belt, balance shaft belt, thermostat, and valve cover gasket. If you ever have to do this it's not an easy job, you have to pull the valve cover, unbolt the alternator, power steering pump, take out the drivers side motor mount, jack the engine up, then start to actually change parts.
Old 07-05-2004, 12:40 AM
akm akm is offline
i feel your pain.
today i got to push my dad's harley home (almost 2 miles) after it ran out of gas.
that was fun, you should try it some time.....
Old 07-05-2004, 12:49 AM
Ghetto Jet's Avatar
Sounds like a good work out akm. Some Harley riders look like they would benifit from pushing their bikes a couple miles a day.
Old 07-05-2004, 12:54 AM
akm akm is offline
yeah, i lost what little fat i had today; now i'm just skin and bones .
Old 07-05-2004, 05:21 AM
Dutchman's Avatar
Old Salt
Ghetto Jet,
Thats one thing nice about the Honda engines, you can treat them bad and they will keep runing. My wife ran the oil out of her CRX more times than I liked, kept on going.
Dutch
Old 07-05-2004, 11:10 AM
honda water pump
i always thought they were easy all you need is a hoist and air tools and do them quit often and they get really easy lol j/k they usually flate rate a few hrs and thats witht the hoist and the air tools.
Jesse
P.s. also some of them have a bulletin out for the balance shaft seal to come out and blow a mess of oil every where.
Old 07-05-2004, 11:32 AM
dmorris1200's Avatar
doesn't play well with others
You callin' me fat now there tough guy! j/k
One time I was on my way home in the weeeee hours of the mourning and my bike just died. I had some problems with my fuel filter in the past and figured she was clogged or maybe I ran her to low on gas. Since it was the middle of the night I just started pushing. By the time I got to the front of my house I almost couldn't walk, I was wiped. Problem was my garage was on a hill and my driveway had a pretty decent incline. I was so tired that I had to go inside and wake up my wife to come out and help push the bike up the driveway and into the garage. In the morning I first checked for gas in the tank (Ok), checked the filter (Ok), carb (Ok). Then I moved into spark check mode, pulled a wire and found I had no spark, hmmm. I looked to check the coil under the gas tank and there was my problem. The primary wires on the coil are held on to the posts (= & -) with small nuts. One nut had vibrated loose and fell right off leaving the wire hanging. A quick trip to the hardware store and she was good to go. Since that day I lock-tite everything I possibly can on that bike. Pushing sucks!
PS. Don't ever get one of those Honda timing belts off a tooth, ooouuch.
BUILT FORD TOUGH
Old 07-05-2004, 11:50 AM
Ghetto Jet's Avatar
60convert thanks for info about the seal and yes it wouldn't have been to bad with a lift in a bay, hell a a paved driveway would have been nice, we were doing this in the stones.
dmorris it's easy to be a tough guy on a message board, but I looked in your gallery, you're not fat, maybe you should lose 15 pounds, but you're not fat. j/k
Old 07-05-2004, 11:59 AM
maybe you should loose 15 pounds
Funny, my wife says the same thing. By the way, a word to the wise. "Maybe you should lose 15 pounds" would not be considered the correct response your wife is looking for.
BUILT FORD TOUGH
Old 07-05-2004, 01:20 PM
Jon's Avatar
Jon Jon is offline
Hotrodders.com Administrator
Wiki Edits: 7314
akm -- I'm tired of constantly reading your posts and finding cursing, overriding the profanity filter, and inappropriate language. I know you're not the only one who does it, but you're one of the very few who does it very often.
Please edit your post.
Please refrain from the constant and tasteless use of inappropriate language on this board.
You've previously been suspended for your behavior on this board. If the language does not improve, you'll be suspended again.
Old 07-05-2004, 03:41 PM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
Bump
Old 07-05-2004, 04:28 PM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
didn't know you could even say that, just tried, guess you can.
K
Old 07-05-2004, 04:39 PM
crazy larry's Avatar
Last journal entry: better comparison before and after shots
i didn't think you could either. wth can't we say pet****? i've never ridden a motorcycle that didn't have one. petc o c k. see. that didn't hurt. ???
Old 07-05-2004, 08:30 PM
akm akm is offline
sorry about that, i'll keep it down.
Old 07-05-2004, 10:35 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
Oh, I don't know......maybe it's the right thing to say if you wanted say....a few good hours of uninterrupted time in the garage by yourself. Then again, you'll be doing a lot of things by yourself!
