HONDA Civic 2002 drive issues - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-05-2008, 10:03 AM
Hi guys,
My Girl got a problem with her 2002 Honda Civic EX Coupe.
I try to find the issue in order to help her and fix it.
While driving the car is making a real loud and bad noise kinda like a airplane.
It is directly connected to the driving speed. So the frequency of the noise gets higher if you drive faster and lower by slowing down. The Volume level on the other hand is pretty consistent no matter what speed I drive.
When I accelerate hard the noice is gone until I let off.
I was guessing on drive shaft bearing but she is telling me the noise exists now since thousands of miles so I would say a bearing would have died long time ago.
There is nothing to feel at the steering wheel at all no vibrating no shaking nothing. Its steering easy and the car is running perfectly straight.
Im out of ideas to be honest.
You guys got any idea???
Tomi
Old 08-05-2008, 10:29 AM
Wiki Edits: 31
could it be an exhaust leak?
a few other things come to mind
bearings in wheels and transaxle
possibly worn CV joints
Old 08-05-2008, 12:37 PM
redlightning's Avatar
If the noise stops on accel.I would say it is inside the trans,but usually Hondas make noise on accel and are quiet while coasting.
It, hard to say without hearing it.
Th-350 no dircet drive manicmehanic75ta Transmission - Rearend 4 05-25-2008 09:57 PM
2002 Dodge Caravan starting issues wllmpndltn Electrical 2 09-04-2007 09:21 AM
Christmas Honda Poem ChevyLuv Hotrodders' Lounge 6 03-20-2005 10:24 AM
I am looking for a 1968 Honda Civic............. neil madsen Hotrodders' Lounge 11 11-12-2002 03:43 PM
front drive shaft in bronco 2 steve norman Transmission - Rearend 2 10-19-2002 11:11 AM
