Hood Clearance - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-09-2007, 11:29 AM
Last journal entry: 69 Mustang
Hood Clearance
I need a little advice. I have a '84 Camaro with a 350 sitting in it. I have a 1406 edelbrock carb. After I placed the spacer under the carb, there is'nt much clearance. I'm in Heidelberg Germany, so I could order a entire hood, but shipping would be more than the hood itself. Does anyone have any recommendations on a good scoop to put on the hood to give me a little more clearance. I've seen one or two online, but I want to make sure I get a good fit and a good look?
Old 09-09-2007, 11:59 AM
How thick is the spacer? "Much clearance", is it "enough clearance" a miss is as good as a mile. If you have an inch or so that should be plenty unless your motor mounts are broken. Maybe a different air cleaner would do the trick.
Old 09-09-2007, 12:16 PM
malc's Avatar
Living At The Speed Of Life
I used a Harwood cowl induction piece on mine from Summit.
Itīs glued on with a few pop rivets left in for good measure.
Tends to let engine smells out when the car is standing idling.
Old 09-09-2007, 12:22 PM
That darn scoop is just the most versitle ever I think. It looks perfect on that car, very nice looking ride there!
Old 09-09-2007, 12:49 PM
Scoop
I agree, that's a nice looking car. Thanks for all the input.
Old 09-09-2007, 01:10 PM
malc's Avatar
I made the mistake of cutting too larger hole in the hood.
If you go for it just cut a circle to let the air cleaner through the hood.
I also did this to stop small children getting sucked into motor.
Correct sequemce for body panel alignment Ripped Body - Exterior 4 10-19-2005 09:14 AM
Hoods not shuting all the way 74_Chevrolet Body - Exterior 5 09-01-2005 08:10 PM
Best ways to straighten a twisted repro door? Ripped Body - Exterior 13 07-04-2005 08:29 AM
"Bowed" deck lid cruzinTLT Body - Exterior 3 03-04-2005 10:24 PM
body parts fitting anyoldchevy Body - Exterior 10 02-20-2005 10:20 AM
