Hood Color Match opinion - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-18-2014, 12:50 PM
One day paint did a " Match" for a hood of mine. What do you think
The left part is what I supplied them to match, the center is what they came up with, and the right is the car
Looks F*&^%^ to me BBB
Old 01-18-2014, 02:54 PM
geezer69's Avatar
Die standin' up
Last journal entry: geezer69 nova 63
Old 01-18-2014, 04:21 PM
That doesn't even look like a blendable match. Kinda hard to tell with the one of the left at an angle. It's also hard to tell just staring at it in one angle as the photo gives us. But that being said, it looks pretty bad.
Old 01-18-2014, 04:43 PM
swvalcon's Avatar
Last journal entry: rust on lt body shell
Did you try playing with some test cards? You can take the same can of paint and end up with about 3-4 different shades just by how you thin it or spray it. Also found you can brighten high metalics just by doing a nice wet clear coat. Spi is bad for this when your trying to match and older factory color as it goes on so nice and wet and glossy. It makes to color pop so much more than factory clear coat.
Old 01-19-2014, 06:08 AM
deadbodyman's Avatar
Wiki Edits: 11
I'm having a little trouble decyphering this post but what I'm getting is you bought the paint and painted it yourself? The color is off so your blaming the guys that mixed it? Well,
The brand has a lot to do with it too...when most guys go to the paint store they never ask how will it match they always ask how much/ they start off wanting the (good stuff) and once they pick themselves up off the floor after hearing the price they want something cheaper,and then cheaper still..usually they end up taking home some of the lowest quality paint ,thinking paint is paint...
usually this is how it ends up...
doing your own paint work is great ,even easy when you dont know anything about it but solving problems like this is what a painter does...so what I say is it looks pretty good......for amiture work....... and if you wanted it to look like a pro did it you should have gotten a pro to do it...what did you expect dont blame the cheap paint or the guys that mixed it and since you did it yourself you cant even blame the painter...So whos fault is it????
Painting is always EZ until theres a problem and it almost always goes back to the applicator or the person that bought the paint (owner)......
I get people coming to the shop saying look how bad this paint job is ,that Maaco does crap work ,I turn around and say it looks pretty good to me......I cant paint a car at all for 300.00 even if the paint was free.....
The first thing you should have done is look at the color when you opened the can and compared it to the car or better yet bring the car to the paint store and have them tint it ot( best possible match) before you buy it...
second...even a very close match is never a perfect match due to fading ,washing and a few other things so no painter in his right mind would ever paint without blending (with a few exceptions) ...or.unless they dont care if it matches or not..
So.learn how to blend, start with a closer mix and never paint if you think the color is off...once you paint it you own it ,its got your name on it...
Old 01-19-2014, 06:53 AM
delawarebill's Avatar
no match paint
did they use a paint reader ??? they come in different brands/names.. but u just put it on the part u want to match and press the button.. comes up with a code they can use..
Old 01-19-2014, 08:57 AM
And those are a serious hit and miss. I have personally used one, it was all over the place. One time amazing match, next time a solid color when the car is metallic!
Old 01-19-2014, 09:07 AM
Come on now, don't be so hard on him. You are totally right, but don't be so hard on him, this stuff has a steep learning curve.
I thought the same thing, why wasn't a test panel sprayed? It's so far off that you would know and not paint the hood. But I don't his experience level.
I have worked with painters that did this day after day, blows me away. When I painted every day I made SURE the color was right before I painted the car. And even then when the car came out of the booth it was checked and if it wasn't right I re-did it right there, I sure as heck didn't park it out in the lot for the bodyman to take it and finish it. I can't believe the mount of cars I have seen with a bodyman putting it together and the color is off a thousand miles! And this goes for doing body work too, when I got done with the bodywork it was paintable damn it! I sure as heck didn't want to have the paint shop find flaws so I had to start over in my stall, I made SURE it was primable before I gave it to them. But again, I have seen bodymen who get the car all cleaned up and blown off then give it to the paint shop for them to point out a bunch of flaws where it has to come back and get a full skim coat! WTH?
Anyway, this is a lesson learned and the original poster was told by the paint shop it was "matched", he took their word on it. Wy in the heck would they say it's matched when it's not?
Old 01-19-2014, 09:24 AM
put up or shut up
it looks like it needs a tad more silver to overcome the saturation of the blue. If you had to you could spray the metallic a little lighter to get the flakes to stand up a little more, but that's a pretty bad match. I'd buff the old paint a little bit before complaining as the old paint will look more saturated with a buff, which is the same direction it needs to go. Would be good to know what color that manufacture recommends it to be sealed/primered over, as metallics are semi transparent and the color behind it has a drastic effect on the overall color.
Old 01-23-2014, 07:20 AM
The picture is kinda hard to tell.. but did you blend on the fender or just panel it?
Old 01-23-2014, 07:24 AM
Which toner has the most grams??
Old 01-27-2014, 07:14 PM
that blue is one of the hardest colors to match,like the others have said spray test panels then blend
Old 01-27-2014, 07:36 PM
yep I was at the place that painted the hood today, they agrred to repaint it at no cost
I am A printer by trade and Match colors 12 hrs a day sometimes.
and you are correct on the tough match as they gave color sample swatches 2-300 different blues in the ballpark of the hood, I could not pick a closer match. What will have to be done is modify the formulas.
Wonder if digital matching would come close??
Old 01-27-2014, 08:48 PM
that works sometimes but that color can change that much with just air pressure and how wet its sprayed
Old 01-27-2014, 08:58 PM
put up or shut up
I get what you're saying and that's a good first look.` The other day I mixed some paint and the most grams were black. I did a paint stick check and it's hard to tell cause the stick will always look more saturated but it was waaay too dark and knew that in the morning I'd have to offset that black with a couple drops of white and a little silver that were in the formula. but someone beat me to the punch and just sprayed it. Came out dark but acceptable.
Problem with SW Dimension Color Match InstinctBlues03 Body - Exterior 12 10-13-2011 11:26 PM
color match scanners proworks Body - Exterior 5 07-21-2009 08:18 AM
Where can I buy an OEM color on line to match my Code? Carrameow Body - Exterior 6 10-02-2006 06:33 PM
I did something wrong, color doesn't match tallpaul Body - Exterior 12 08-07-2005 09:18 AM
How Do I Match Original Color Of Fabric? HotRodMan Interior 2 06-15-2005 10:23 PM
