hood flutter foam - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-08-2012, 05:44 PM
skip99's Avatar
hood flutter foam
any preference? fusor 121, dura mix 4374?
theres about a 1/4 inch or more gap on the 51 hood brace to the skin, any ideas how to keep it clean looking while using the foam?
does either one have a adhesive property? meaning..if I laid a wet blanket on the top of the hood would it hold a little? my hood has one small area that is high,,light pressure lines it up
51 chevy truck
Old 04-10-2012, 09:28 AM
I would be interested to know as well. I have the same problem on my 72 Demon.
3M used to have the perfect product but it was discontinued a few years back.
Old 04-10-2012, 09:58 AM
BarryK's Avatar
The Duramix 4374 is made for that specific purpose and will not shrink or expand, also as far as adhesion going from memory (scary) it had a lap sheer of around 1500, not as good as the 4040 or the bonding agents that were 2800+ per square inch but still pretty good.
I have never used the fuzor and know nothing about it but have used the Duramix since it came out and have never seen a problem.
EDIT:
Also the Duramix is NOT Foam, it is a polyurethane and foam should never be used in this situation.
Old 04-10-2012, 06:14 PM
ogre's Avatar
the 'Duracell Project'
my 58 chevy truk hood had deteriorated foam blocks in there
i replaced them with semi hard foam weather strip
the peal and stick type
worked great
Replacing a metal hood with a fiberglass hood dasyhard Body - Exterior 9 07-12-2011 10:18 PM
Hood pins verse stock hood latch 62440 Body - Exterior 3 08-23-2010 09:30 AM
Best Anti flutter foam? baddbob Body - Exterior 12 08-02-2009 05:39 PM
soft top flutter Cape Cod Bob Body - Exterior 1 05-30-2009 06:45 PM
Slight flutter on the Vac guage - What's the first thing to do? Arns85GT Engine 32 09-13-2005 04:36 PM
