Hood latch 1978 pacer - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-20-2009, 11:07 AM
HELP 1978 pacer woody wagon the hood latch is broken is there a trick to get it open ? slim jim unbolt hood hinges ? thanks steve
Old 03-20-2009, 02:56 PM
302 Z28's Avatar
Hi Steve, I changed your thread title to help locate it better with the search function.
Vince
Old 03-20-2009, 07:33 PM
sorry, I couldnt resist
Old 03-20-2009, 08:09 PM
Steve, you'll have to remove the grill to access the latching mechanism.
If it's a cable release system, you might be able to reach up from the bottom, cut the cable and pull the wire to open the latch......
Old 03-20-2009, 08:52 PM
302 Z28's Avatar
ROFLMAO
Vince
Old 03-20-2009, 09:19 PM
Let me see, Steve Martin, a 1978 Pacer, hmmmmmmmmm.
Ok, I'll bite, I am not sure but you may be able to get a long extension thru the grille to unbolt the latch. The hinges are just about out, I don't remember (having only worked on two Pacers in my life) but unless it is VERY different from just about every car made, there is no way to get to the hinge bolts. If I knew where one was at the wreckers or something I would go check it out for you but I don't know where to find one!
aligning hood gto_ron Body - Exterior 8 03-25-2009 06:22 PM
Body alignment 1949HevyChevy Body - Exterior 2 11-12-2008 04:49 AM
adjusting door fender gaps on 60s ford? 62galaxiguy Body - Exterior 1 06-13-2008 07:43 AM
Hoods not shuting all the way 74_Chevrolet Body - Exterior 5 09-01-2005 07:10 PM
Removing fenders? Jag Daddy Body - Exterior 3 11-26-2003 04:42 AM
