-   -   Hood Louvers (http://www.hotrodders.com/forum/hood-louvers-176550.html)
tmuysprv 04-19-2010 12:37 PM
Hood Louvers
Anyone know of a shop in NC (preferably in or close to Raleigh that can stamp louvers ?
Looking for something along these lines or close to this:
http://i81.photobucket.com/albums/j2...r/DSCF6833.jpg
Tomlowe523 04-22-2010 09:35 AM
If you don't mind having the hood cut up a bit, these are much easier to install, and much cheaper than having them stamped into the hood.
http://cgi.ebay.com/ebaymotors/1-Pai...Q5fAccessories
tmuysprv 05-26-2010 07:54 AM
Well I do mind cutting the hood, that's kinda why I was asking.
Anyone ?
fordhemi 02-11-2013 08:00 AM
Let me know if you find someone.
I have a hood that needs doing too.
Thanks,Ron
M5StudeGuy 02-12-2013 09:19 PM
Since I saw this threads about louvers I wanted to throw out a question.
I have a old truck... hood is just a sheet of factory bent metal. (what I am trying to say is it doesn't have all the cross bracing like today's cars do)
I am going to cut louvers in my pickup hood to help with heat issues.
Will this weaken the hood, strengthen the hood, or make no difference.
I assume the number of louvers and location will have some effect also..??
kso 02-13-2013 11:28 AM
Generally the form of the louver makes up for the loss in strength from the pierced hole, but yeah too many of them or having them in a flat area, things can get a little flimsy or warped.
It's good there's no bracing in the way, otherwise you just cut it out and weld it back in.
Didn't find any in NC with a quick search, just the normal-type fab shops that you probably wouldn't walk into with an old car hood. Me I'd ask a hot rod shop if they knew anyone, if nobody here does.
fordhemi 02-13-2013 11:39 AM
Located a guy just outside of Raleigh.
He is renovating an old barn for his shop and should be ready to go in a couple of weeks.
PM me for more info.
Ron
