Hood Misalignment - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-08-2007, 10:39 AM
Hood Misalignment
Hi Guys,
I'm working on a 67 Chevy C10 and run into a problem with my hood lining up. I purchased the hood from Classic Industries and the mating fender as well. I've got every thing lined up with the exception of the lower passenger side part by the grill. If I raise it up to match the fender the rest of the hood is above the fender. If I keep it down low the grill will be misaligned by 3/8". Any ideas how to address this problem?
Thanks,
Hurdy
Old 06-08-2007, 11:23 AM
new pics
Pics of my problem
Name:	DSC03053 (Small).JPG
ID:	21724   Click image for larger version
Name:	DSC03054 (Small).JPG
Old 06-08-2007, 11:51 AM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
I haven't tried any repro hoods (I assume that's a repro hood and fender?). I've put on some repro 60-66 chevy truck fenders and the fit varies a LOT on each one I have used. IMO it would be difficult to build a show truck from the repro 60-66 stuff...too much cutting & rewelding for me. I have had a problem with the front tip of the 60-66 fenders not curved correctly.
Just this week I had a hood to fender problem on our 69 dart with a GTS bulge hood. The drivers side had a big problem, as the middle of the hood edge, halfway between the front & back was raised up 1/2". I almost wanted to put the hood on the floor and step down on the edge
I ended up using a 1/2" thick 4x4 angle iron about 5 feet long under the hood edge and then a big C-clamp with a long block of wood on the top side. It worked slick, but my hood has a better spot to be able to do that, compared to your hood.
You could tell if the hood is bent wrong by making a cardboard tracing of the curve from front-to-back, then cut the cardboard to the line and the compare it to the side that fits good? I was going to do that, but I knew the hood was bent, not the fender.
Off the subject, but yesterday was spent with a bottle jack in the trunk to push up on the rear deck metal at the front of the rear trunk lid to get the lid to start to get close to fitting.
Old 06-09-2007, 01:23 AM
Missaligned hood
Thanks F&J. I'll try the carbord and see if it matches up with the driver side.
Hoods not shuting all the way 74_Chevrolet Body - Exterior 5 09-01-2005 07:10 PM
Best ways to straighten a twisted repro door? Ripped Body - Exterior 13 07-04-2005 07:29 AM
"Bowed" deck lid cruzinTLT Body - Exterior 3 03-04-2005 09:24 PM
Removing fenders? Jag Daddy Body - Exterior 3 11-26-2003 04:42 AM
body panel alignment gmonkey Body - Exterior 5 09-01-2003 06:50 PM
