hood scoop - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-01-2005, 02:31 AM
fennerford's Avatar
New Member
hood scoop
i want to make a hood scoop but i am not sure what material i should use. is there any material that would be the best or should i use or doesnt it matter.
could i build it out of thin sheet metal like aluminum or steel?
Old 01-01-2005, 09:10 AM
advanced design's Avatar
Just havin' fun.....
Last journal entry: Wheels and tires
Yes you can make a hood scoop out of steel or aluminum. If the hood is steel make the scoop out of steel and if it is aluminum make it from aluminum. Further information on working with steel and aluminum can be found here. http://www.metalmeet.com/
Old 01-01-2005, 10:21 AM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
hood scoop
You can buy a generic fiberglass bolt on
Old 01-03-2005, 02:39 AM
Last journal entry: Some pics
Re: hood scoop
Or make one.
You could probably do a bit more wild shapes with fiberglass. At least I know I could do more that way with my limited skills.
Old 01-03-2005, 03:06 AM
New Member
I play with fiberglass all day.. SUPER easy... If you want to go that way let me know...
