Hood scoop bonding - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-03-2011, 07:02 PM
Hood scoop bonding
I want to use a fiberglass hood scoop on my metal hood for my el camino. I need to know what kind of bonding agent I need to attach the scoop. I'm wondering if fusor or some other adhesive would work.....Thanks, James Randolph
Old 05-03-2011, 07:13 PM
put up or shut up
yes, one for disimilliar materials to handle the differing expansion rates. Use flexible filler and all flexible products thereafter. I personally never did one but read about the procedure. Also states to screw it in w/sheet metal screws but not tight enough to squeeze it out. Can't speak from experience but it sounds like reliable info.
Old 05-03-2011, 08:33 PM
Fusor 116 is what I used. And after talking to them, I believe they said it needs 1 mil of thickness or something, soa roughed up piece of FG shouldn't have any problems.. So you don't need to screw it in so loosely it's sticking up a mm or something!!
I then blended with Evercoat polyflex..
fingers crossed!
Old 05-04-2011, 08:42 AM
S10xGN's Avatar
Gotta love a turbo!
Both of my "rods" have 'glass scoops bonded to steel hoods with 3M body adhesive, then finished off with (some type of) bondo putty. Both are still looking as-new to date...
Russ
Old 05-04-2011, 09:08 AM
Thanks
Thanks for the advise, I'll probably go with the fusor product, I've had good luck with their products even though it has been some time since I have used any. Jamesr
Old 05-04-2011, 09:47 AM
I use large head pop rivets and dough.
Old 05-04-2011, 07:55 PM
On a horizontal surface like a hood, you can use weights
such as old phone books to hold the scoop down until
the adhesive cures.
Old 05-04-2011, 08:30 PM
put up or shut up
that sounds much better than screw holes you have to clean up later.
Old 05-08-2011, 01:13 PM
I'm not sure about that..
I used screw holes, but they get filled when you smooth it out. No biggie.
Old 05-10-2011, 07:44 PM
Last journal entry: few more pics
I used 6 small head rivits on each side. Then added fiber glass on both sides, and then had to go back with a light weight filler. Mine is on a camaro with a hardwood 4 inch cowl. I still haven't gotten it done. I applied the filler, and the used a bondo putty, and i noticed a crack in the putty. So im going to smooth it out, and add more filler and maybe a better quailty putty. Which i probably laid the putty to thick, i normally use it for small holes in the filler. Which im learning from experience, and i've spent alot of time to get it smooth. The lip on the scoop is why im having to add so much filler to mine to make it level with the rest of the hood.
Fiberglassing a hood scoop on a metal hood Quarter Flash Body - Exterior 11 09-25-2007 06:22 PM
hood scoop Michael Sparks Body - Exterior 1 08-26-2006 08:25 PM
hood scoop help 76ChevyNova Body - Exterior 1 07-16-2006 08:45 PM
hood scoop fennerford Body - Exterior 4 01-03-2005 02:06 AM
hood scoop chad bonzworth Body - Exterior 3 05-18-2004 06:08 PM
