Which hood??.Scoop or cowl??. - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-17-2013, 08:49 AM
1Gary's Avatar
Last journal entry: 383 dyno sym
Which hood,in your opinion,for a 1/8 mile Malibu 7.50 drag only car is more effective??. Thanks.Oh yeah,looks don't matter to me,just what works best is all that counts.Thanks.
Old 07-17-2013, 08:52 AM
how tall of a scoop or cowl? Old pro-stock snorkel type or modern pro-stock type scoop?
Old 07-17-2013, 01:13 PM
1Gary's Avatar
This VS a 6" cowl:
Old 07-17-2013, 01:15 PM
1Gary's Avatar
This VS a 6" cowl:
Old 07-17-2013, 01:45 PM
If its drag race only , i like the prostock in the pic ...if you make a pan off the carb , glue some foam to it so it seals when the hood is shut it would help keep the air to the engine. Like the seal on a cowl induction hood as on the 69 camaros and 70 chevelles.
Keep in mind , you should still have some form of a breather so you dont suck any dirt or foan into the carb !
i had a cowl induction hood on mine and ran low 10s.
What engine are you using for a drivetrain n how fast to you hope to go ?
Malibus are great cars , good weight transfer and easy to make go fast toys...Have fun .
JC
ID:	75770   Click image for larger version
ID:	75771   Click image for larger version
ID:	75772   Click image for larger version
Old 07-17-2013, 02:14 PM
1982 SS's Avatar
Flamethrower
Last journal entry: More Cooling fan pictures.
Go for the Cowl. I don't think the aerodynamics are worth much at this speed, and I bet the cowl will be easier to see around. I'm planning on a 4" Glasstek cowl as money allows.
cowl induction hood V.S. carb scoop blakjak Hotrodding Basics 1 12-27-2011 11:03 AM
scoop or cowl bigdog7373 Body - Exterior 7 07-11-2010 03:25 PM
steel cowl hood scoop gonzodw Introduce Yourself 1 11-20-2004 10:20 AM
welding a metal cowl hood scoop to a metal hood? project66 Body - Exterior 7 11-10-2004 10:25 AM
coustom cowl scoop Novaman78 Body - Exterior 10 11-04-2003 09:24 AM
