hood scoop question - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-12-2010, 05:28 AM
hood scoop question
I'm 80% sure I'm going with a ram air induction, however. Should I happen to see a scoop design that really suits the 69 impala I'll go for that cause the girl wants for paint anyhoo. But heres my question. Does a person have to re-brace the hood to account for the hood bracing he's cutting through for breather hole? If I recall all of my hood bracing intersects over the breather. I cant imagine that can all just be cut out without replacing with something. I'd like thoughts and also some possibilities of scoop designs. Thankyou
Old 06-12-2010, 07:35 AM
pepi's Avatar
How’s that hopey-changey thing
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
well you could just reconnect the bracing all around the area that is being remove for the scoop .. but I would do that before I cut it, to keep the shape true ....
Old 06-12-2010, 07:41 AM
Is this the accepted method people use?
Old 06-12-2010, 01:18 PM
ericnova72's Avatar
More for Less Racer
If you are adding a steel scoop, like a weld-on cowl induction scoop, the added bends and shapes of the cowl scoop adds a good deal of stiffness when it is welded to the hood.
I have never seen anyone add a hood scoop and try to refit the underhood bracing, it isn't necessary, and will interfere with the carb/air cleaner if the goal was to add more carb to hood clearance for tall intakes and/or spacers. Bracing will also be in the way if you are going to build an air pan to seal the top of the carb to the scoop.
The hood will hold it's shape just fine, it will just bend easier in an accident is all.
corvette front clip rhinz1966 Body - Exterior 12 01-11-2010 04:57 PM
Help...Original Cuda Mopar Shaker Hood Scoop? CarNewbie Hotrodding Basics 1 02-22-2008 05:47 PM
1951 chevy hood ? Area_51 Body - Exterior 6 02-15-2008 04:21 PM
how can I fix my hood scoop mess? bigwildgrin Body - Exterior 6 11-21-2006 10:05 AM
Door Alignment Ron M Body - Exterior 2 08-21-2004 01:43 AM
