Hood support/strut shock chart or dimensions - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-13-2008, 11:45 AM
47chevy's Avatar
Last journal entry: Here is the car after paint
Went to the parts house and tried to get the open and closed measurements of some hood struts. NO luck. All they wanted is what year and model of vehicle I wanted them for.
I am needing a couple of struts for my trunk lid on my 47 chevy coupe. I have removed the original latch, installed hidden hinges and now the original support is not going to work.
Does anybody have the chart or know where to look??
Thanks
Old 11-13-2008, 12:09 PM
47chevy's Avatar
I found it. It was buried with the shock absorbers chart.
Here is a link to it. Pages 53-55.
http://www.monroe.com/catalog/docume...engthSheet.pdf
Old 11-13-2008, 12:50 PM
The problem is you still don't know how much resisance it will have. Where you mount this as far as the leverage created could make a BIG difference from one shock to another even though they have the same length open and closed!
Old 11-13-2008, 02:31 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Austin Hardware and Supply..they have the gas struts up to 250 lb capacity and a chart of specs to allow the customer to specify the struts to suit their needs..They are an industrial supplier so you may need to go thru a jobber to buy from them..
Sam
Old 11-13-2008, 05:39 PM
47chevy's Avatar
Thanks for the info. My simple mind did not think of that.
aligning hood gto_ron Body - Exterior 8 03-25-2009 07:22 PM
Hoods not shuting all the way 74_Chevrolet Body - Exterior 5 09-01-2005 08:10 PM
Best ways to straighten a twisted repro door? Ripped Body - Exterior 13 07-04-2005 08:29 AM
body parts fitting anyoldchevy Body - Exterior 10 02-20-2005 10:20 AM
Removing fenders? Jag Daddy Body - Exterior 3 11-26-2003 05:42 AM
