Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Hood and trunk alignment tip, for you pros too!
Old 01-13-2012, 09:59 PM
MARTINSR MARTINSR is offline
Originally Posted by evolvo
How did you know I was fighting this on my car? It's exactly the issue I'm having. After I close the hood I can push it down into position. Guess I'll give it a shot tomorrow, hope it works. Just curious, would putting the shim at the other bolt "shim it up"?
YES that would raise the hood.
But hold on here, what kind of car are you talking about? If it's an older car you don't need to do this, you need to "rotate" the hinge back to lower the hood. This lowers it MUCH, MUCH more than simply pushing the hinges down.
