Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Hood and trunk alignment tip, for you pros too!
  #54 (permalink)
Old 09-23-2012, 09:10 AM
tech69 tech69 is offline
put up or shut up
you can slot em to get a little more wiggle room but if you can push it down by hand and it doesn't naturally lay flat then lube it up and move the joints around and get it flowing again. As I said before, it's the most common problem with hinges so shims are out of the question unless it's absolutely needed.
